Old 09-03-2008, 08:28 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Drive Shaft Question
Anyone evey had a drive shaft that just did not want the yolk to slide on the shaft?? Whats the best grease to use to make this easier??
1971ChevyTruck is offline   Reply With Quote
Old 09-03-2008, 10:57 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Drive Shaft Question
Lamb fat. not kidding.
dwcsr is offline   Reply With Quote
Old 09-04-2008, 09:31 AM   #3
68gmsee
Active Member
68gmsee's Avatar
I'd make absolutely sure that there wasn't anything else preventing it from sliding in first. If it's the original yoke, check for a damged spline or that it's lined up properly. If it's a different one check for mismatch parts.
The yoke is supposed to slide in and out as the truck rear wheels go up and down and if it doesn't move freely, you could damge rubber mounts and/or feel the vibrations.
68gmsee is offline   Reply With Quote
Old 09-04-2008, 09:45 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Does it have and index spline? (spline that is twice as wide as the others that keeps yoke from being installed in position other than correct position)
WIDESIDE72 is offline   Reply With Quote
