Old 09-03-2008, 08:58 PM   #1
Inthuwind
Straight jacket required
Inthuwind's Avatar
Copper fuel lines?
Has anyone used copper fuel lines, or is there a problem with disimiliar metals??
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 09-03-2008, 09:34 PM   #2
lpaine
lpaine's Avatar
Re: Copper fuel lines?
I don't know if it's a good idea, it'd be easier to bend for sure, but I don't know if it might cause you problems if it reacts badly to gas, I'd stick with steel lines myself, someone else will chime in more knowledgeable than me. Why would you want copper feul lines anyway?
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 09-03-2008, 09:54 PM   #3
Inthuwind
Inthuwind's Avatar
Cuz I'm a plumber and like you said, it's easy to bend.
Old 09-03-2008, 09:59 PM   #4
odog
odog's Avatar
I came across 2 wrecked trucks the other day with copper lines. The 1st 1 had two saddle tanks and 1 behind the seat tank and they were all connected by copper lines, the other just had a copper line running from the sending unit to the bottom of the cab, then rubber. Not sure how the gas reacted to the copper though. Just thought it was interesting.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 09-03-2008, 10:02 PM   #5
Inthuwind
Inthuwind's Avatar
Yeah, I'd like to find out how it reacts to it first.
Old 09-03-2008, 10:03 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I've seen them used and they seem to hold up ok, but I would still go with steel or stainless steel if it were me!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-03-2008, 10:26 PM   #7
Boog
laying low
Boog's Avatar
For safety reasons. In the event of an accident the copper tubing would colapse and split sooner than standard fuel tubing.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-03-2008, 10:53 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Copper is prone to vibration fractures so its not used on gasoline lines. Nickle-copper is ok.
dwcsr is offline   Reply With Quote
Old 09-03-2008, 11:14 PM   #9
Shane
Shane's Avatar
dwcsr is correct ... copper will "work harden" and eventually crack due to constant vibration ... think of taking a piece of coat hanger or bailing wire and bending it back and forth and it will eventually fracture at the bend point.
lots of guys have used copper in the past, but I'm not sure I would take the chance when much better alternatives are available ... especially considering how flammable gasoline is.
Shane is offline   Reply With Quote
Old 09-04-2008, 12:07 AM   #10
kwmech
Would never use them personally b'cuz of the already mentioned potential problems----------however, I do see them quite frequently on these trucks with the added on side tanks, along with the plastic lines.
Old 09-04-2008, 12:55 AM   #11
D'Animal
X - 2
I use 3/8" coated steel tubing. It is generally used for tranny lines. Works great and hold ups teriffic.
D'Animal is offline   Reply With Quote
Old 09-04-2008, 06:10 AM   #12
Copper`s sure enough easy to bend.But,that`s the problem.It`ll keep on bending.Whenever you work around it you`ll end up bending it when you didn`t want to.Te steel has a rigid quality,bends nicely with proper tools,and stays that way.
Old 09-04-2008, 07:10 AM   #13
Inthuwind
Inthuwind's Avatar
That's good enough for me, thanks everyone for your inputs. I'm going to go with stainless from Inline Tube. Thanks again.
Old 09-04-2008, 10:59 AM   #14
Orange
Licensed to Thrill!
Orange's Avatar
I used copper from my filter to the carb. Reason being my inlet on my Edelbrock was just going to be hard to hit and make it look right without the fitting I needed, so, I used copper because it was easy to bend. BUT - I also put rubber fuel line over the copper just in case.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 09-04-2008, 11:13 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
when I got the longhorn, it had copper lines on it... ftom the tank to the pump. It looked like it had been there for many years and was still in good shape.
However, I agree with the above... not a good idea.
Old 09-04-2008, 11:27 AM   #16
stynchrr
stynchrr's Avatar
I found that alot of folks use copper to fix rusted fuel lines up in the north east. Never saw one cause a problem but I never had one with copper for a long time.
stynchrr is offline   Reply With Quote
Old 09-04-2008, 01:44 PM   #17
Myself
I'd say the only problem would be potential breakage during an accident. Which is the same potential problem for steel lines. Gasoline is petroleum based, as is LP (propane or butane), and those systems are hooked up with soft copper lines. So as far as any chemical reactions over the years, I'd say that's not going to pose any long term problems.
Myself is offline   Reply With Quote
Old 09-04-2008, 02:23 PM   #18
Lippyp
English Chevy Owner
Lippyp's Avatar
I have copper fuel lines on my truck (OK its Kunifer, copper Nickel) with no problems and have had many cars over the years with copper. In our wet climate thars far less chance of a leak through copper fracturing than there is through a steel line rusting!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 09-04-2008, 05:01 PM   #19
68gmsee
Active Member
68gmsee's Avatar
20 years ago, I used copper tubing on my 69 Chevy when I converted it to a 350. (I couldn't find a replacement.) It's still there and never had any problems.
Truck is parked now and when I redo the engine I will get the metal one since it's easily available and looks better. But, in a pinch, I wouldn't hesitate to do it again.
68gmsee is offline   Reply With Quote
Old 09-04-2008, 05:25 PM   #20
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I am not advicating copper, but for a show truck.... Pollished copper would look cool!! WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-04-2008, 09:10 PM   #21
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
copper is used on custom old school choppers for the look, i don't think i would use it on a classic truck though. I would use just a piece like ORANGE did though.
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 09-05-2008, 05:56 AM   #22
see ten
WTB this ad
see ten's Avatar
It does look cool though doesn't it?
see ten is offline   Reply With Quote
Old 09-05-2008, 08:10 AM   #23
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've had a copper 3/8 fuel feed line from the fuel pump to the carb on my 292 for 31 years. No problems.
Old 09-05-2008, 03:34 PM   #24
corn
What are these made out of?
They sure look like copper under the chrome when you cut one up...
corn is offline   Reply With Quote
Old 09-05-2008, 03:37 PM   #25
jb4short
Damn Yankee
jb4short's Avatar
I think most cars and trucks in the 30's and 40's used copper fuel lines
jb4short is offline   Reply With Quote
