Old 09-03-2008, 10:16 PM   #1
Lobo'74
Lobo'74's Avatar
Drip Rail/Inner cab rust
PO had painted the '67 before I bought it. Looked good. 5 years outside have shown me there was some rust under that paint.
PO filled in the drip rails with filler and painted over them. Drip rails have some rust. I now also have two very small holes/bubbles in the cab interior above the windshield. Still solid metal around them.
Here's my idea. Get the Eastwood rust converter and Eastwood silver rust encapsulator.
Small screwdriver as cleaning pick and brass wire brush out all material from the filled drip rails.
Treat drip rails with rust converter. Spray rust converter into inner cab area through the small holes and through the holes where the attach point of the visor goes.
After the rust converter dries completely paint the drip rails and drip rail undersides with rust encapsulator. Also spray it into the inner cab area through same holes as the rust converter.
Re-spray white (color of the cab) topcoat on the drip rails. Run seam sealer in top of painted drip rails.
Think it will work?
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 09-04-2008, 10:31 AM   #2
Lobo'74
Lobo'74's Avatar
Re: Drip Rail/Inner cab rust
Anybody?
"Truck"
'67 small window
Old 09-04-2008, 01:46 PM   #3
Myself
Sounds like a plan to me, at least for another 5 years.
Myself is offline   Reply With Quote
Old 09-04-2008, 01:51 PM   #4
chevguy7
chevguy7's Avatar
That is basically what I am doing right now on my truck. I think the only way to get on the inside of the roof without cutting it all up is to spray through the holes for the sunvisors.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 09-04-2008, 03:58 PM   #5
prg machine
prg machine's Avatar
exactly what I did with my truck using POR 15
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
