09-04-2008, 01:42 AM | #1 |
Disc/Disc proportioner?
Was curious what proportioner I need with my new rear disc setup (Speedway)? Any ideas?
09-04-2008, 07:12 AM | #2 |
Re: Disc/Disc proportioner?
I would help you out as I am mechanically challenged.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-04-2008, 07:28 AM | #3 |
Nothing to see here.....
I ordered mine from CPP. I believe the pn# was PV1.
I know Speedway has one, but I don't have the pn# or catalog in front of me.......
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
09-04-2008, 08:37 AM | #4 |
Restoration Virgin!
order one from here....they are made right here in NC....
http://www.piratejack.net/Proportion...lves-Kits.html I believe it's a PV4 on this web site.....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-04-2008, 09:27 AM | #5 |
its all about the +6 inches
unless you got an entire kit, from master cylinder to front brakes to back brakes.... there will be no proportioning valve that is just right. If you only do part of the brake system, the right hand literally has no clue what the left hand is doing.
I highly recomend plumbing a 67 - 70 distribution block, and then an adjustable proportioning valve. |
09-04-2008, 09:49 AM | #6 |
I used a drum brake p-valve, and cheep offshore roters on the rear and it worked out perfect. With the cheap rotters, you lose about 20% of your stopping ability over stock, or good quality roters, so for me it worked great.
09-04-2008, 09:52 AM | #7 |
I also recomend reading up, on stuff written by people who know whats what.
If you are mixing and matching, there's hyd line pressure readings you should take, to verify things like "a drum proportioning valve worked perfect". pumpkin... if I was a betting man, I'd bet a kick to the daddy parts, that your drum brake proportioning valve is not just right. it's just good enough. |
09-04-2008, 10:56 AM | #8 |
Licensed to Thrill!
Call Mike -
http://bumpandgrindgarage.com/ He's a supporting vendor and will give you a discount on an already great price. He will also give you technical support. DLB Last edited by Orange; 09-04-2008 at 10:56 AM. |
09-04-2008, 11:31 AM | #9 |
I'm not taking the "parts kick" but I will bet that you have dragging pressure on the rear lines. This will create more heat and wear out your "cheap rotors" even faster. It is not good for anything else for that matter. Drum systems keep 10PSI in the lines with a "residual pressure" valve.
09-04-2008, 12:21 PM | #10 |
Distribution block, this block was used on all 67-70 trucks, with front drum / rear drum brakes. The block is bolted below the master cylinder and is not a proportioning valve as it does not modulate line pressure. If there is a loss of pressure in either the front or rear braking systems, it will activate the brake warning light in the dash. Since this block provides equal pressure to the front and rear brakes it is also great for 4 wheel disc applications.
These distribution blocks do not have residual pressure valves in them. Residual Valves: These valves are used in brake systems where the master cylinder is mounted lower than the calipers, typically under the floor. This is a check valve that keeps either 2lb (disc) or 10lb (drum) of pressure in the system to prevent the fluid from running back and overflowing the master cylinder. These valves should be mounted as close as possible to the master before the proportioning valve. These valves are not needed on firewall mounted master cylinders. Thus the reason our distribution blocks did not require a residual pressure valve. A alternative to using a distribution block is a disc/ disc prop valve which again applies equal pressure to both. I was taught this by Inline Tube. GMCPaul |
09-04-2008, 01:01 PM | #11 | |
Never Ending Projects
This is great info. I am getting ready to do a 4 wheel disc conversion on my '68 and now I know I will keep my drum/drum valve and not change to something else. I will plum in a adjustable valve after the distribution valve on the rear line, just so I can tweak the rears.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
