Old 09-04-2008, 07:58 AM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Painting my engine question
I need to spruce up my engine as it looks pretty awful. Is it possible to paint an engine in situ as I don't have the space or facilities to pull the engine at the moment? I'm happy to remove inner/outer fenders if neccesary to make access easier. As I've got a new intake, valve covers, dizzy to go on it makes sense to spruce the block up first.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 09-04-2008, 08:03 AM   #2
wHATANERD
wHATANERD's Avatar
Re: Painting my engine question
It's possible, but I would have the engine compartment and engine steam cleaned before painting as paint doesn't stick to oil and grease very well.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 09-04-2008, 09:35 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
clean everything you want to paint. This is th4e hardest part when it is in the truck still (can be done though)
When you think it's all clean, do it two more times.
I say strip the engine as far as you can.... belts, hoses, fuel lines.... all the 'dressings' on the engine need to come off. I would even pull the fuel pump and exhaust manifolds/headers.
As you are masking things with yesterdays news paper... grab the alluminum foil from the kitchen. You can mask off odd ball shaped things (cross memeber, sway bar, brake lines) with the foil, wrap it, squeeze the foil, anf it's there.
Have fun, take your time, clean clean clean.
Here's one I did... engine never came off, intake never came off, did it in my dirt driveway, all in all I think it took me a day and a half. (obviously not straight through)
Old 09-04-2008, 10:58 AM   #4
see ten
WTB this ad
see ten's Avatar
71see10 did this one while it was still in the truck. He pulled the inner fenders and painted them black and then he shot the inside of the outer fenders and firewall green. It turned out great.....but he has above average skill and patience.
I may have some better pics somewhere...If I find em I'll come back and add them to the thread.
see ten is offline   Reply With Quote
Old 09-04-2008, 11:55 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
Firewall and inner fenders etc are all fine, its just the block and heads themselves that need paint. The intake manifold will be coming off to be replaced with an edelbrock performer anyway, its got ramshorns on it so assuming I can get them undone I'll take them offand as much of the other bits as I can. I was going to use POR15's engine paint as that seems to get a reasonable thumbs up from people.
Phil
'67 C10 long fleet.
Old 09-04-2008, 12:40 PM   #6
TotalChevy1
TotalChevy1's Avatar
If you take the front clip off it makes it very easy.... strip the motor down as far as you can, degrease.... The old pan and around the trans were the hardest, but mask and you should be fine.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 09-04-2008, 02:20 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Yes, use POR 15 for sure. You can even brush it on if you do not want to mask everything off and you will get fantastic results!
leddzepp is offline   Reply With Quote
Old 09-04-2008, 07:26 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I like to finish clean with brake cleaner.It seems to make the surface completely oil free and the paint sticks better.It will eat paint so make sure it doesn't get on paint you want to keep and is completely dry.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-04-2008, 09:49 PM   #9
71 super
71 super's Avatar
you will be happy with por15, but dont thin too much as it will run and it is a pain to get off,but it looks as good as powder imo.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-04-2008, 09:59 PM   #10
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Painting my engine question
I used Dupli Color engine enamel on mine and didn't even get all of the grease off of it, it's been 3 years now and it still looks as good as the day I painted it!!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
