Old 09-04-2008, 07:30 PM   #1
1971c20
1971c20's Avatar
i am starting to hate the chevy 350
so, i come home from school and it started to idle really bad, it had a bad vibration and there is a hesitation from a stop or slow roll when i push the gas. what can be the issue it has new oil, i dont know what to do, when in drive at a stop it viberates and the oil pressure slowly keeps lowering.
1971c20 is offline   Reply With Quote
Old 09-04-2008, 07:32 PM   #2
truckdude239
truckdude239's Avatar
Re: i am starting to hate the chevy 350
frist thing is to stop driving ti something is really wrong, i read somewhere ona small block chevy stock oil pressure at idel should be like 10psi and go up 10 psi for every 1000 rpms
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-04-2008, 07:34 PM   #3
truckdude239
and check to make sure all cyliders are fireing
David fuller
2000 Tahoe 5.3l 378
Old 09-04-2008, 07:43 PM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: i am starting to hate the chevy 350
Well it could be a small number of things, plugs fouled, wires bad, distributor cap burned or corroded, or wet, rotor corroded, any of these will cause it to run rough and shake, as far as the oil pressure dropping does it do it after it runs for a while, does it drop down to nothing or just 1 or 2 marks above? It's normal for it to drop after it has warmed up and it is idleing especially if it is running as crappy as you said it is!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-04-2008, 10:53 PM   #5
1970 chev truck
Weldin' it up
1970 chev truck's Avatar
is vacuum advance functioning properly(vac line cracked or missing?)
-Paul-
RIP El Jay
Dirt is for Racing, Asphalt is for Getting There
If need be, send me an e-mail at cbm_racing_90@hotmail.com
1970 Custom/10 LWB 4X4 350/TH350
2003 Silverado 1500 Ext. cab
1974 Kawasaki 175 F7 Enduro
2002 Polaris Edge X 700
1970 chev truck is offline   Reply With Quote
Old 09-05-2008, 01:13 AM   #6
1971c20
1971c20's Avatar
well i just ghanged the plugs and wires and the oil, still shaking,so i guess ill have to change the cap and rotor, could this be motor mounts?
Old 09-05-2008, 01:48 AM   #7
sleepertruck72
sleepertruck72's Avatar
Whatever you do dont hate it. Talk to it fix it and take her out just like you would a woman. Everything will work out
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 09-05-2008, 05:50 AM   #8
Don`t hate what you obviously don`t understand.Changing oil has no effect what so ever on how a vehicle runs.The 350 is a legendary motor that has no rival.A well tuned motor can run like that due to a failing torque converter or other transmission problem,even.
Old 09-05-2008, 07:05 AM   #9
truckdude239
or abad carb try changin your fuel filter
David fuller
2000 Tahoe 5.3l 378
Old 09-05-2008, 07:27 AM   #10
big_al_71
big_al_71's Avatar
If you are not sure get someone to help you that really knows it is ok sometimes to let someone help. I have been there so many times that I am not sure then I ask. A 350 chevy motor is so simple that it is scary..Dont hate it...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
