Moderator
![]() Join Date: May 2007
Truck tilt column or Van tilt column?
I am looking at pulling a tilt column that appears to be factory stock. How can I be sure? The wiring harness is the original style horseshoe without an adapter, but can't that be swapped out? The connections under the hood appear to be factory...other than the tranny linkage. There is no SPID label, I already checked. Thanks.
Re: Truck tilt column or Van tilt column?
I adapted a Van tilt for my truck, to make a van tilt column work in one of our trucks the neutral start/backup light switch would have to me relocated up the column. If the column has not been modified near this switch it probaly a truck column. Also there is a plastic pin in the colapseable shaft that has to be drilled out to shorted that van column about 3 inches so that it will work in the a truck. If the pin is not drilled out it's a truck column. Hope you find this info helpful.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
truck tilt. the short splined shaft is a good indicator, shaft on vans is about 4/6 inches long. truck about 1.5/2 inches long.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
its all about the +6 inches
thats the real deal there.
More Cowbell....
Truck tilt.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Moderator
#7 | |
Moderator
dude... I'm not always right.
But it IS a truck unit though. ![]() |
