09-05-2008, 10:00 AM | #1 |
Corvette wheels on a 72 truck
I would like to put a set of 78-82 aluminum corvette wheels on my 72 truck, I know that the lug pattern is different, but things that I don't know are: will the depth/spacing of the corvette wheel fit and will the center hole fit over the grease cap in the front and over the hub in the rear. If anyone as any experience with this swap I sure could use your help!!!
Thanks, Wayne |
09-05-2008, 01:15 PM | #2 |
Re: Corvette wheels on a 72 truck
Wayne,
If I recall those Corvette wheels are 15" x 8" with a 4" offset, so they should clear just fine. Is the 5 lug truck bolt pattern 5x5 or 5x4.5? The Corvette wheels should be the smaller 5x4.5. I can't be certain about the center holes of the wheels, but the cars used the same type of hub/bearing assembly, so you may be in luck.
-- Shawn '67 Short Step '70 Short Wide |
09-05-2008, 01:24 PM | #3 |
Yes, the truck lug pattern is 5 x 5 while the corvette is 5 x 4.5. There's alot of work involved in getting the lug pattern changed.
But another problem, is the truck hubs are bigger, than the ones on cars. I measured mine, it is 3" Diameter. Where a car wheel I have is 2.5 - 2.75. So the hub is to big for a car wheel.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
09-05-2008, 01:33 PM | #4 |
Ok, I thought the lug patterns were different, I just wasn't sure about the hub holes.
09-05-2008, 01:42 PM | #5 |
Guys,
Thanks for the information, I have adaptors for the lug pattern issue. Also, I can have a guy at work that can machine the center hole out, if that will work, but do you think once I get the wheel mounted on the truck that there would be enough clearance for the tire or wheel not to rub while turning? Thanks again! Wayne |
09-05-2008, 01:59 PM | #6 |
i have already done this on my 68......its actually 4.75 bolt pattern on the vette. Now this pattern is the same as camaro, so you buy camaro rotors, chevelle or camaro calipers with spindles, just put new bearings and its all good to go. or if you really going to do it all brand new.....nolimit.net they will sell you the complete kit....it works just as good if you dont though, i never bought the kit...
09-05-2008, 02:24 PM | #7 | |
Do you have a pictures of your swap??? I am interested in seeing these. How did the ball joints work. I thought the ball joint shafts? would be different size.
09-05-2008, 02:54 PM | #8 |
Project Junkie! Fishing Poor!!
Is this what you are looking for? Sorry, I do not have any specifics on this truck though. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-05-2008, 03:04 PM | #9 |
Wes,
Basically yes, but I want to use the 76-82 corvette wheels with the almost square slots. I don't know if the size of the wheels are the same. Thanks, Wayne |
09-05-2008, 04:51 PM | #10 |
The LuvShack Garage
Interesting, Might ponder this idea a lil deeper
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-05-2008, 05:09 PM | #11 |
I'M TRUCK CRAZY!
neat
09-05-2008, 10:18 PM | #12 |
i actually do not have pictures. sorry. http://nolimit.net/prodinfo.asp?number=ED%2D6370C now on that link......thats where i got my parts list......then off to the junk yard i went....i did have a little trouble getting right bearings to fit but it took a while of trial and error just get some try it on get some try it on till i got the right one...and on my back end i pulled a rear end of a 98 z28 camaro cut off all the brackets and dropped it n the rear http://www.ecklerstrucks.com/product...dept%5Fid=1861 that link is where i got the idea to hold my rear end down to my truck. instead of paying 160 for that kit i bought some steel and made the bracket myself....this is how it came out.....
09-05-2008, 10:22 PM | #13 |
i am doing the entire conversion to 5 by 4.75....because everything is from corvette or camaro in my truck....engine and trans are from 91 vette....rearend 98 z28...and i will most likely be using c6 vette wheels.....only because i found them in 20''...
09-05-2008, 11:21 PM | #14 |
laying low
Or if a fella only wants 'vette wheels on his truck there is most likely some adapters available out there. I know of a 90's Chevy truck with this vette style wheel on it, no adapters needed. ( like on the red one above that Wes posted )
Not to discount your accomplishment Danman.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
09-06-2008, 08:35 AM | #15 | ||||
Union Electrician
Wayne, I have an easy solution to your troubles. I have the wheels pictured in my garage. They were on a parts truck I bought a few years ago and I kept the wheels. They are not exactly the corvette wheels you are wanting to use, but they are so close everybody thought they were corvette wheels. The best part is that they are 5 on 5 lug pattern and will bolt right up to your 72 without any mods at all, saving you quite a bit of time and $$$. The fronts are 15x8 and the rears are 15x10, they are in great shape and just need to be polished up and they would look like new again.Here is a couple of pics of the wheels and one of them on my old parts truck. I have cleaned up the fronts since the pics were taken and they will polish back out, just need to spend alittle time with them. If you are interested in the wheel just send me a PM and we can talk about them. If you click on my build thread in my sg andn on the first two pages is where we had discussed the wheels and what they are. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
