Rear axle's
I just bought a 68 c20 for my son, i would like a little advice. Which axle is in this truck, "Dana something?" by the glove box it has 4.10 gears. I am also wanting some higher gears to save some fuel.
![]() Join Date: Jul 2005
Re: Rear axle's
Don't hold me to this, but it looks like a corporate 10.5" axle. Good luck finding a new gear if it is. If you do find a gear set for it please let me know as I have the same axle in mine
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach. Can have new owner for the right price. "Life is tough, its tougher if you are stupid" (John Wayne) My buddys truck for sale here. http://67-72chevytrucks.com/vboard/c...p?product=2676 |
Restoring it $200 at a time...
Re: Rear axle's
aka HO52 from Eaton. Mine had a 4.57 gearset, and Keep on Trucking is right; you probably won't find new gears for it. I wound up putting in a 3.54 Dana 60 (look for a 1/2T big block donor truck) and have been quite happy with that. After 12 years, maybe it's time to update the speedo drive.....
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 Last edited by hounddogs!; 09-05-2008 at 02:23 PM. |
Re: Rear axle's
Yeap it's a HO52. Parts are almost none existent for those. Your best bet would to swap in a Dana 60. You can find these in some newer 3/4 trucks. But you would have to weld some brakects on to it for the trailing arms and panhard bar. Or just swap it over to leaf spring , then you options would be almost endless. It really isn't that hard when you get into it.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
![]() Join Date: Aug 2003
Re: Rear axle's
Change to a Dana rear.
Re: Rear axle's
If you're up for welding on new brackets I'd recommend the 14 bolt. You can go all the way up through 2008 on that one, and the newer ones (2001 up) had factory rear discs.
Ford sterling or dana 70 rears would work too (and commonly have 3.55's), but the main problem with them is that the hubs stick out so far you'd have to have a very large center cap on your wheels to cover them.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
its all about the +6 inches
Re: Rear axle's
For bolt in ease, MOST big block powered C/20 should have a dana with a 3.54 gear.
As far as bolt in rears, that's as close as you'll be getting. |
![]() Join Date: Aug 2008
Re: Rear axle's
Member "uncle" has a dana in the parts forun:
354 Dana single trac from a 69 Longhorn. $175 OBO. Please respond to post. I have a spare 3/4 ton dana, but not sure of gear ratio. |
Re: Rear axle's
A longhorn would have leafs instead of coils. If he wanted to do that kind of fab work, he'd be better off with a 14 bolt rear.
Re: Rear axle's
I have a coil spring one too,but shipping is HIGH.
Re: Rear axle's
Thanks for all the help everyone, it will all prove to be helpful during this little adventure we have.
Rich |
Re: Rear axle's
I'ld keep the eaton and put in an overdrive transmission.
#13 |
Re: Rear axle's
