Old 09-05-2008, 01:15 PM   #1
Primer69er
Just gettin started!
Primer69er's Avatar
97-98 dash, seats in a 69?
i've been searching for the past 3 days, for a picture i saw of a 67-72 with a dash from a 97 or 98 truck. my idea is to put that dash with the seats, and carpet in my 69. my biggest concern is weather or not the steering column with tilt from that truck will fit in my truck. any ideas
heres a pic of the style
Primer69er is offline   Reply With Quote
Old 09-05-2008, 01:30 PM   #2
BarryB
BarryB's Avatar
Re: 97-98 dash, seats in a 69?
No offence, but your going to do all that modding, and your worried weather or not if the column will work.
I don't see why not because they still use the same type steering box. And if you put the dash in. the mounting area should be the same. You might have to lengthen or shorten the steering column shaft going to the steering box. But that should be simple enough since it is suppost to have a sliding shaft for a frontend collision purposes. That's my $.02 worth
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-05-2008, 01:34 PM   #3
Primer69er
Primer69er's Avatar
i dont know much about the steering columns but i just figured if everyone uses a van tilt instead of a truck tilt, maybe there was a reason
Old 09-05-2008, 02:02 PM   #4
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
This is the only one i Remember having Seen................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 09-05-2008, 02:08 PM   #5
Putter
More Cowbell....
Putter's Avatar
That's the one that I pictured as soon as I read this, too.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-05-2008, 02:18 PM   #6
toomanytoyz
Luv the Crewcabs
Thank's for those Pics, I will add those to my Collection..............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 09-05-2008, 02:18 PM   #7
BarryB
BarryB's Avatar
If you are refering to the original style columns for these trucks. Then the reason for using a van tilt, instead of a truck tilt is because cost. A truck tilt cost alot more than a van tilt.And a van tilt is easier to find. Hope that answers your question. But if you are going to do the newer dash conversion I would use the steering column from the donor truck, just for the "LOOK" purpose.
Two rules in life.
Old 09-05-2008, 02:39 PM   #8
Primer69er
Primer69er's Avatar
very similar to that, except i want the full dash. there was a thread a couple weeks ago, someone was asking about custom dashes and someone posted a pic of one with a full 98 dash. either way, do you have more info on that truck, maybe a build thread?
Old 09-05-2008, 03:33 PM   #9
BlueJeep
BlueJeep's Avatar
You'll definitely want to use the same column as the dash. The reason is that dash is molded for a "rectangular shaped" column where it meets the dash. If you use a normal round column, you will have a large unsightly gap there. Not to mention rewiring will be easier if you retain as much of the dash/column as possible.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-05-2008, 03:43 PM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
With a complete dash swap, your only real trouble will be where it goes through the floorboard. May have to cut you a patch out of the donor truck.
sneakysnake is offline   Reply With Quote
