Old 09-05-2008, 01:48 PM   #1
Hawker7
High Mileage on 350??
I’m building my truck on a budget and don’t know what to do about the motor. It is a 350 with 124,000 miles and the one time I started it up it ran and idled smooth with no smoke. Anyone know if 124k is a lot of miles for a 350, or if there is anything I should consider doing to it to make sure it is reliable? I planned on just pulling it and replacing the gaskets on valve cover, oil pan, timing cover, etc.
Hawker7 is offline   Reply With Quote
Old 09-05-2008, 01:53 PM   #2
grayw0lf
Re: High Mileage on 350??
I wouldn't think that 124k is a lot for a 350. Unless it came from a 1 ton that was constantly pulling a heavy trailer, I wouldn't worry about it.
Most late model V8's in small trucks are all getting over 200k, easy.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 09-05-2008, 02:08 PM   #3
El Jay
Gone to greener pastures
I'd do what you are planning and run it until it dies, then do a rebuild.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 09-05-2008, 02:35 PM   #4
steelhorse
steelhorse's Avatar
A lot of new trucks get 200k plus on their motors with little cyl wear if properly maintained.A fuel injected motor will outlast a carbed one due to fuel wash.I say drive till dead repair/repeat
steelhorse is offline   Reply With Quote
Old 09-05-2008, 03:21 PM   #5
chevguy7
chevguy7's Avatar
Mine has about 145k on it and I am going to wait until it dies. Other than a small tune up I'm basically ignoring it during my build.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs
http://67-72chevytrucks.com/vboard/s...d.php?t=272458
2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds
chevguy7 is offline   Reply With Quote
Old 09-05-2008, 03:27 PM   #6
BlueJeep
BlueJeep's Avatar
One of my last trucks (1990 TBI 350 3/4 ton 4wd) had 280K before it needed to be replaced. It seemed to have a good amount of power until about 260K, and then it started to show signs of power dropping off.
My last Suburban had 210K when I got rid of it, and I had just returned from a trip from Iowa to Utah and back pulling my Jeep on a trailer (7K total weight). No sign of any lost power at that mileage.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-05-2008, 03:30 PM   #7
Hawker7
Anything I should check when I have it somewhat apart? Any gaskets that should be addressed besides the valves covers, oil, and timing cover?
Old 09-05-2008, 03:53 PM   #8
68gmsee
Active Member
68gmsee's Avatar
You didn't say if it's the original 350 (year?) but if it is, and has never been rebuilt, you've got a good engine. Most engines of that era didn't last much past 50k, 60K without some problem like worn cam, timing chain, valves, rings or lifters. The engines being made now will last way past 100k, but not then. I think it has to do with the metal alloys being used now.
I'd say do a compression check and make sure all the cylinders are within specs.
Give it a good tune up: timing, spark plugs, distributor cap and rotor, plug wires, filters,etc.)
Replace all the gaskets and seals that you can like oil pan, valve covers and change the oil.
And, as mentioned above, drive it until it won't go...
68gmsee is offline   Reply With Quote
Old 09-05-2008, 04:02 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you guys are comparing apples to oranges.
Tyhe late model engines, starting around 87, started being built to go hundreds of thousands of miles... the old stuff, in all reality, was made to last A hundred thousand miles.
If you want to do it and do it right (do it once) then pull it, and have it looked at. At a minimum, you'll want to do a cam, T-chain, oil pump, and most naturally, bearings. More likely than not, you'll be getting an overbore and new pistons, a valve job and resurface on the heads. (complete rebuild)
If your plans include lotsa miles, you may want to look into a late model 5.7 block. That roller cam alone will double, if not tripple the life of your engine if treated right.
Old 09-05-2008, 04:02 PM   #10
68 50th
68 50th's Avatar
In 97 or so I bought a 88 3/4 ton 350/TH700 from the original owner.
It had over 480,000 miles on the clock at that time, it was the original engine in it and it only had a valve job done to it at around 300,000 miles. It ran just perfect but I sold it whitin a year or so. It was very well maintained, the first owner was a newspaper distributor company. Here's a pic of the truck.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 09-05-2008, 04:15 PM   #11
Hawker7
yes, forgot to mention it is out of my 72 C-10 and is original.
Old 09-05-2008, 05:59 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Like Andy said, there is a BIG difference between the early 350's and the 87 and newer motors. Not only did they build them to better standards, the addition of fuel injection makes a huge difference in longevity.
One of the problems with older carb motors is the carbs have a tendency to run rich as the become older. That extra fuel dumped raw in the cylinders washes the oil away and promotes cylinder wear.
As suggested, if she's running good, pull the pan and valve covers. If it all looks clean reseal it and run it till she dies.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-05-2008, 06:19 PM   #13
jef5150
Inline 69
jef5150's Avatar
While you have it out, you(someone) should replace the rear main seal.
jeff
jef5150 is offline   Reply With Quote
Old 09-05-2008, 06:26 PM   #14
68gmsee
Active Member
68gmsee's Avatar
I’m building my truck on a budget and don’t know what to do about the motor. It is a 350 with 124,000 miles and the one time I started it up it ran and idled smooth with no smoke....
All of the above responses are correct. But in my humble opinion, the gentleman is on a budget and if the engine is within specs and running smooth, I wouldn't necessarily tear into it. It may go for a few more years with a little tender care and no unnecessary stress like heavy towing, racing, etc...
Old 09-05-2008, 06:51 PM   #15
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I have 175K on the 350 in my 1990 Chev. Had to do the valve seals recently but it still runs great and has tons of power. If it ain't broke, don't fix it???
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 09-06-2008, 11:27 PM   #16
grayw0lf
My next door neighbor has over 350k on the 4.3v6 in his S-10. It obviously smokes a bit, but runs great.
05' Dodge Neon
94' Seadoo SP
Old 09-07-2008, 10:18 AM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
My $0.02 .If it runs good and you're on a budget,pull it,gasket it ,paint it and tune it.While you are running it til it dies,buy a junkyard core and a smallblock rebuild book.Start tearing it down and planning/building the replacement you really want.As time/funds allow buy/build that engine.When it's done you can swap as needed.The bst thing about doing it this way is that you get to drive the truck until you can plan a weekend for the swap.It's really hard to get pumped up about a project you can't drive, and more so when you're waiting on fundage.This makes even more sense if it's your DD.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-07-2008, 10:25 AM   #18
Gray Ghost
Gray Ghost's Avatar
Andy's right on this one....I had 124 on the clock when the motor went south and from my experience that was a lot of miles. Newer motors are lasting over twice that with no problems. Our S-10 4 banger has over 240k on it!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 09-07-2008, 11:43 AM   #19
Southpa
Southpa's Avatar
I've checked the numbers on my motor. ie. suffix code stamp and embossing on pass. side, both tell me the block is a 1970, so I can assume original motor. Since I've owned the truck (13.5 yrs now) I've put 164,000 miles down. The odometer read 000,598 when I bought it and I've watched it zero out again and then some. I've literally taken this truck to hell and back (well, almost literally ) I've run it w/ a bad rad for a while and watched temps exceed 260 deg. F Its been continuously driven on some of the roughest logging roads and has hauled some of the heaviest loads and has never run better.
I have yet to do any major engine work. Compression test back in 2001 averaged 155 lbs all around. I have a slightly used Competition cam to go in and asked my mechanic buddy about putting it in. He asked me, "Is your truck broken and/or not running right?" I said, "no" and his response was, "then why mess with it? Wait 'til it dies or stops working within your needs". The truck has never run better and I can assume 364,000 miles on the clock.
I'm pretty sure the compression is a result of a good buildup of carbon. But a well-maintained engine should last a long time. I've replaced valve seals a couple times and do regular oil changes. I live in a moderately mild climate (Vancouver Island) and temps rarely go below freezing so I've been using 20W50 oil. This is an original Van. Is. truck, even better than a California truck because paint doesn't fade as fast.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 09-07-2008, 03:23 PM   #20
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I decided to go with a crate motor, because my block has been built once and has at least 213K miles on it. It could be 313K because I just don't know for sure. It was used to tow a 26-ft camper and whatever else may have been asked of it.
I weighed the costs of doing a proper rebuild, with the possiblities of a bore meaning new pistons, etc. Being sure the total package would be reliable and still money-smart lead me to the decision I made. Luckily, I have found a new crate 350, still wrapped and palletized, for $1K. Yeah, it's a bargain, but I'd still do it for more money. Machine work and parts could easily run $800. The new engine has a warranty, the rebuilt one would not.
Member Nr. 2770
Old 09-07-2008, 04:01 PM   #21
mrein3
mrein3's Avatar
I respectfully disagree with those who say tear into it and rebuild it.
At 124k you probably need a timing chain. If you have no record of it ever being replaced, now is a really good time to do it. Since you are planning on replacing the timing chain cover gasket, you should plan on doing the chain too.
How long an engine lasts is DIRECTLY related to how you maintain it. If you keep the oil fresh, keep it in tune, and don't constantly and consistantly buzz it to high R's, 124k is nothing.
New gaskets, new chain, spend your hard earned cash on other items in your restore.
One more thing, change the front oil seal in the timing chain cover. If you have a groove in your harmonic balancer - which you probably do, this can leak. You have 3 options to stay ahead of this potential leak.
1. Buy a new balancer and replace the oil seal with a stock replacement one.
2. Buy an offset seal and replace the stock one - use your current balancer.
3. Buy a sleeve that you whack over the snout of your current balancer.
I have done all three of these and all three options work.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-07-2008, 07:18 PM   #22
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My dad's 84 truck has about 350,000 on a 350 we rebuilt in our basement...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-07-2008, 07:40 PM   #23
Hawker7
Since I'm on a limited budget I can't afford to rebuild, but can devote my time to pulling the motor and cleaning everything up on the motor itself, and the engine bay. I want to replace all the seals as I don't want anything leaking and making a mess of my driveway, or the engine bay that I'm cleaning. Since this will not be a DD, I will probably only put a few thousands miles on a year, and hope to have the motor last for some time.
Old 09-07-2008, 10:50 PM   #24
72 CustomCamper
huh ???
Letting them sit for long periods is what dries out seals...
Chuck
