Dual battery setup question
How do you guy's have your dual batteries hooked up? Thanks
A sweet 2000 Deville..... |
its all about the +6 inches
Re: Dual battery setup question
I have the positive to positive, then down to the starter, one neg to the frame, and one neg to the engine.
End result is 12 volts, and double amps. |
just tie the positives together and ground each battery and you are good. I have hooked up hundreds this way. This is how every diesel on the road is hooked up.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Built 4 Speed
Agreed with above but there is also a switch you can get in between the setup (cant remember the name) that basicly lets the car run off of one battery until there is a extreme load ie:starting winches sound systems, that engages when neccicary so you dont put a large load on alternator when it isnt needed..
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 09-05-2008 at 06:44 PM. Reason: to much of the same word. |
member #16
![]() Join Date: Dec 1999
Heres a diagram if anyone wants it.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#6 | |
One battery running starter, ignition,.... basic functions Auxillary battery running accessory stuff....Winch, lights, amps, etc The idea being that if you run the aux battery down with other equipment, it still starts.....and if you happen to run the starter battery down you could "jump" from the aux. This does not double amperage or voltage though. |
Always wrenching!!
mine i just ran each positive to the starter and grounded each to the block.
my old Tahoe i got a continuous running solenoid and ran the batteries to it. it isolated the batteries when off and charged both when running. also run a toggle switch to the inside and you can jump start your self from your second battery.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
I have a radical idea!
I have been running dual batteries in my '69 C-30 ramp truck for about 6 years now, and I have never had to replace the alternator.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
I decided to buy an isolator. I got a Sure Power one (they actulally invented them). It basically, like previously stated, runs two batteries seperatly. One runs the normal vehicle functions, and one is for aftermarket stuff. The isolator detects which battery needs charged and automatically switches between the two to charge. The benefit is that you are not overtaxing the alternator and if you are parked (vehicle off, thus, shutting off one battery) you can use up all of the juice in one battery and still start the vehicle. I have been looking for this setup for a while, but I could only find $200 kits. My co-worker had one of these in his tool box, so I google'd it and found their website. I then had my parts department get me one from an aftermarket parts store locally. I went with a 120 amp model and it was only $60. I was going to do a 95 amp model which was only $45 but they did not have one locally.
I have never had good luck with isolators! If I was gonna seperate the two I would use a 200 amp relay or a continuous duty solenoid and just seperate the two when the key was off
The LuvShack Garage
Subscribed so I will remember this
![]() I ran an Isolater when I competed in USAC and IASCA and all it did 4 me was make me eat alternators.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
In boats they run isolators and battery switches all the time with no harm to alternators
- Josh Im not white trash, I'm one step above that..... more like white clutter |
#13 |
I put tons of big stereo's in boats and most have pergo switches but I have only seen 1 boat with an Isolator!
I put 10000 worth in a 47ft fountain at the beginning of last summer an I just just finished a 35 ft also.
#14 |
Truck and auto performance nut
Pergo? isn't it Perko?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#15 |
#16 |
Built 4 Speed
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
#17 |
It wasn't mine I just did the 34 speakers and 3 amps and 2 batteries. I have pictures of it somewhere!
#18 |
if has triple 502's. I couldn't afford to run it if it was free!
#19 |
the biggest fount i got to work on was a 38 nice boats but we just started to install these isolator kits is got a on off switch and an isolator for charging i like the isolators for dual batteries it works nice
