Old 09-05-2008, 07:03 PM   #1
bean
68 seat vs. 69 seat
A friend of mine recently gave me a 68 seat. I like it much better if for no other reason it folds forward. It's also in way better shape than the other one. He told me though the tracks are different for the 68. Is this the case? If so, will the mounting holes in the floor be different? Thanks.
bean is offline   Reply With Quote
Old 09-05-2008, 07:58 PM   #2
Re: 68 seat vs. 69 seat
Far as I know they mount in the same place as long as they are both benches. Should be a bolt in swap.
Old 09-05-2008, 08:38 PM   #3
bean
That's what I would think but he says the 68 track won't bolt to a 69 seat and vise versa. Does anyone know for sure? Thanks.
Old 09-05-2008, 10:28 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you have both seats, how much trouble is it for you to check them both and see what the measurements are? Even if you have to drill a new hole or two, what's the concern? If the earlier seat is in better shape than the later seat, just bolt it in. There really shouldn't be any difference in the mounting for either seat. I've been looking at and sitting on a '68 "Buddy Seat". Looks to me like one would replace the other.
Member Nr. 2770
Old 09-05-2008, 10:34 PM   #5
drivethechevy
drivethechevy's Avatar
all the bench seats 67-72 for pickups(not sure about burbs) will bolt up, my dad has a seat out of a 69 in his 71, i have a seat from a 72 in my 68 my 69 as the seat from my 68 so that swap will deffinately work
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 09-06-2008, 10:19 AM   #6
bean
My friend was right the track for the 69 seat doesn't fit the 68. the 68 is wider so the 69 tracks won't work.
Old 09-06-2008, 12:06 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Strange.... I could swear that my 69 Chevy seat fit perfectly in my 68 GMC. I did that 15 years ago and don't remember having any problems.
Recently, I bought a seat out of a 71 or 72 Chevy and also used it in my 68 GMC and didn't have any problems with that one either. Maybe it's because it's a GMC?
Last edited by 68gmsee; 09-06-2008 at 12:44 PM. Reason: Used 69 GMC... Should have 68 GMC.
68gmsee is offline   Reply With Quote
Old 09-06-2008, 12:23 PM   #8
jorgensensc
jorgensensc's Avatar
it shoud bolt right up. Maybe something is funny it the set. Can you swap the tracks on the seats?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-06-2008, 12:35 PM   #9
bean
I only have tracks off the 69 seat and they just are long enough to bolt to the 68 seat. Would have thought this would be alot easier lol
Old 09-06-2008, 02:48 PM   #10
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yes they are identical, it will bolt right in with no modification. The only difference is the seat is the back!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-06-2008, 08:02 PM   #11
bean
they are not identical. guess i'll have to find mounts for a 68 seat. the problem is where the mounts bolt to the back of the seat that's where it's different
