Need frame help...
The PO tried to weld his own bumper brackets onto the front and rear of my 2wd 72 blazer. Unfortunately he managed to butcher and burn holes instead. I would like to know if the rear part of the frame (the part that angles down) is the same for a pick up and a blazer?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Re: Need frame help...
I know truck frames do not bend like this but could i use a truck frame for a donor?
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 09-05-2008 at 07:44 PM. |
just lovely, quality work
The LuvShack Garage
Looking at your siggy, why not lop them off and run a roll pan?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Aug 2003
You could use the truck ends and go with the truck bumper brackets.
![]() Join Date: May 2006
Frame horns are out there, I found a set for the front. Rears should be available as well...Check out the classified and run a WTB, guys on here part out all the time
Gotta love them PO's
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-05-2008 at 10:23 PM. |
huh ???
Why not just lob them off and run 71 rear brackets?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
I have some frame ends, and I'm close
I am undecided about a roll pan because I also like the sport bumper. Can someone explain the difference between the bumper brackets? Pumpkin, sending you a pm.
Wow that really is some top notch work there
lol |
The LuvShack Garage
Now that I look at it again, I think your rear horns are fine,
just grind of those welds, and adjust the end tabs, whalaa
The fellow who did the "welding" ended up melting through the vertical sides of the horns. You can kind of see it next to that bolt on the left horn
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 09-09-2008 at 07:13 PM. |
#13 |
My truck is in pieces!
i have a clean frame in my garage. I am in Abbotsford if interested.
#14 |
Could someone post a picture of the 2wd 71 style frame ends? If I end up cutting off the end I need some kind of reference where to cut. Could a pair of front horns work in the back as well?
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 10-06-2008 at 07:17 PM. |
