newly minted old timer
mod to alternator bracket. no more shaking!
![]() ![]() ![]() ![]() moive of running motor... no wobbles at all! (same video of us braking in the cam) just welded at piece of flat stock metal to the top at a T. trimmed, grinded,painted.. finaly, i hated that alternator shaking all the time.. smooth as glass now baby! weehoo
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban Last edited by mtdave2; 09-05-2008 at 10:20 PM. |
Sierra Grande Club
Re: mod to alternator bracket. no more shaking!
That looks like a good idea! Can I use your idea if mine shakes?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
I'm a poor spectator
No vid...and what does smoke as glass mean???
![]() EDIT:Well, it's fixed now...
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 09-05-2008 at 10:13 PM. |
typeo .. smooth as glass
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
In the second picture, it appears that the two pulleys
are not in alignment. It you place some washers or spacers behind the bracket, it will move it alternator and bracket away from the head and line it up. Could this be the difference between a long and short water pump? I am not sure. It would be better to have the two pulleys in line. EdB |
#6 | |
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
This is a perfect mod.Great idea.You should have been working for GM.I`ve seen fatigued/broken lower brackets before,too.All the lateral support is in those since they are cast and rigid.
#8 | |
Active Member
![]() Join Date: Jul 2007
I'd double check that just to make sure. What you will notice, if it's off, is that the belt will start squeeling at you prematurely. |
#9 | |
1997 GMC Sierra Ext 1965 Mustang |
Official Site Guitar Shredder
I mad my own a few years ago.....I will post pics....It was super easy to do....
#11 | |
Always on the hunt...
![]() Join Date: Sep 2006
Another easy fix/cure is to find an identicle upper bracket and double'em up, intalled back to back of one another.
