lower control arms with bag plates and bag cups
I've got a set of 67-72 lower control arms with new moog ball joints. The ball joints are for the 73-87. Also is a set of air bag plates and hardware to bolt them on. Everything has been sprayed with POR 15. The shock mounts have been modified but will still accept stock shock location with a shock stud. The arms are $50 plus shipping. The plates are $40 shipped.
I also have a set of cups for a 67-98, $30.00 shipped. ![]() ![]() ![]() ![]() |
![]() Join Date: Feb 2001
Re: lower control arms with bag plates and bag cups
Super Bump.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
How do the cups work with the front airbag? And what needs to be done to the front shock mount?
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 09-06-2008 at 02:22 PM. |
#4 | |
Nothing needs to be done to the lower shock mount. You just need to purchase a pair of shock studs like these. The lower shock mounts where modified to achieve a more desirable shock angle when bagged. Last edited by jlaird; 09-06-2008 at 09:17 PM. |
I may be interested if you still have these for sale. Can you explain the benefit of the cups vs plate? I would need them for the front of a 3/4 ton with 6" slam specialties bags.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#6 | |
Just saw I had a response on this thread. Sorry for the delay. Cup vs. plate...not a huge difference, I just like the plate because it eliminates any potential for the bag rubbing. |
