Old 09-05-2008, 10:54 PM   #1
Jwill41
Jwill41's Avatar
th350 woes
I just bought a 71 Custom Camper/20 with a 88-90 model 350 engine and th350 tranny. The tranny does not engage in any gear. It feels like it is in neutral all the time. I noticed just before dark that there is no vaccume connected to the modulator. Would this keep it from going in gear? I am really puzled as it will not even try to move.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 09-05-2008, 11:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: th350 woes
you check the fluid level?
Old 09-06-2008, 08:41 AM   #3
Jwill41
Jwill41's Avatar
Re: th350 woes
yep
Old 09-06-2008, 09:16 AM   #4
LONGHAIR
Re: th350 woes
Dumb question.......is the torque converter bolted to the flexplate?
LONGHAIR is offline   Reply With Quote
Old 09-06-2008, 10:46 AM   #5
steelhorse
steelhorse's Avatar
Re: th350 woes
Does it feel like it "clicks"into each gear?
steelhorse is offline   Reply With Quote
Old 09-06-2008, 11:45 AM   #6
Jwill41
Jwill41's Avatar
Re: th350 woes
full of fluid
clicks in all gears
Old 09-06-2008, 12:29 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: th350 woes
It should have a vacuum attached to it.
68gmsee is offline   Reply With Quote
Old 09-06-2008, 12:44 PM   #8
MotorSeven
Restoration Desperation
MotorSeven's Avatar
Re: th350 woes
The modulator(vaccuum) line will not keep it from shifting, it will however affect how/when it shifts. Linkage?
RD
MotorSeven is offline   Reply With Quote
Old 09-06-2008, 01:02 PM   #9
gintaras
Re: th350 woes
I know you said it won't engage in any gears, but that sounds like a broken direct drive ring, reverse an L1 SHOULD work, if not, sorry I couldnt help
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 09-06-2008, 02:01 PM   #10
steelhorse
steelhorse's Avatar
Re: th350 woes
If you have all the above sounds like rebuild time.
