radio has a winning sound
i bought a new radio and it has a winning sound
someone said i needed to change plug wires not sure about that i do have a electric fuel pump would this be the cause thanks for any help |
Inline 69
Re: radio has a winning sound
move your power wire to another fuse.
you just getting bleed through(?),Probably from your alternator,it goes up and down kinda like an "audible tachometer".If you get a ticking noise thru your stereo more than likely you've got a loose plug wire grounding out and again it bleeds thru your power line. jeff ![]() |
Make sure you have realy good ground. You can also run your speaker wires through the plastic conduit stuff. Clean power supply is important too. It should run through a separate fuse from anything else. If that fails get a FM noise filter. It can be a real pain to eliminate the niose.
I had to run a 8 gauge ground wire to my dash straght off the neg batt cable and all my accessories to that ground. This is on my 97 GMC, I got rid of 99.9% of the noise through my sterio system. I still get a slight bump noise when I first touch the brake pedal. Havent figured that one out yet.
-61 c10 short step -67 c10 short step -71 k10 long fleet -77 k20 long fleet (gettin all the goodies from frankentruck) -79 c30/k30 3+3 frankentruck (cab and frame for sale) -99 GMC yukon daily driver |
"alternator noise" if it wines up and down with the rpms could also be a bad ground. i own a stereo shop and come across this every once in a while. are you running just a deck and speakers or any amps or subs?
if your grounds are good and you have a designated power source and you still have problems there is also something called a noise filter or ground loop isolator. check w/ your local audio shop and they should have one.
Cheap radio??
Tim |
Darn,I thought I was going to learn about a great radio to use with a "winning" sound.Or,read a comment about someone who just realized how good the original radios sound when you actually pull an AM station in clearly.As far as a whining sound goes,do you have resistor-type plug wires?How about plugs,do they have an "R" in the number?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-06-2008 at 07:25 AM. |
#8 | |
1969 4x4 Nothing beats a good rock drill and some dynamite |
Moderator
![]() Join Date: May 2007
Inline 69
[winning ]-(noun) oscilating sound usually associated with automotive stereo related noises
see also (whiner)-Person or Persons usually unaware that "winning" is the correct terminology when used in a stereo related question on an internet forum ![]() jeff ![]() Last edited by jef5150; 09-06-2008 at 12:36 PM. Reason: spell |
#11 | ||
Tasty Cakes!
![]() Quote:
![]() I felt the same way most of u guys did... I thought the OP had found a new kick ass radio! Anyway, gary67, most of these guys gave you solid info. First thing to check is the ground. Make sure the ground wire is attached to clean metal. Then make sure your main power wire isn't being shared with anything else. The spark plug wires could also be a problem if they aren't shielded. Last resort is a ground loop isolator, but I consider that a band-aid. Good luck, and if you do come across a 'winning' radio, please share ![]()
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Inline 69
#13 |
I "cite" all of my spelling corrections from here...
http://www.merriam-webster.com/dictionary/cite ![]() gees, everbody needs to lighten up!
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
#14 | |
Tasty Cakes!
![]() Hope you have a pleasant day too! And Gary67, did you get it fixed?
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 09-06-2008 at 04:34 PM. |
#15 |
We all managed to figure out what was meant and nobody cares all that much about grammar around here,anyway.I just say something when I see a post is not what I expected from the title.Just chit chat.Now,about that radio...
