Old 09-06-2008, 12:54 AM   #1
AllenKarber
Throttle Cable/Return Spring setups
What kind of throttle cable/linkage is everyone running? What about a return spring?
I'm tired of mine trying to hang up all the time!
AllenKarber is offline   Reply With Quote
Old 09-06-2008, 01:37 AM   #2
ValveTubeHead
ValveTubeHead's Avatar
Re: Throttle Cable/Return Spring setups
stock linkage
Moroso p/n 64919 for Holley 4150 4bbl...works great.
Matt
'65 LWB Fleetside
'63 SWB Fleetside
ValveTubeHead is offline   Reply With Quote
Old 09-06-2008, 09:44 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I used the original pedal, and just made a new rod out of aluminum. Tapped one side and L shaped the other end.
For the return spring, I actually drilled a tiny hole in the protruding pipe plug and hooked the spring there.....
Here's a not so good pic:
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-16-2008, 09:56 AM   #4
MikeN
MikeN's Avatar
67 Camaro 396/375 throttle linkage, Moroso return spring kit...
MikeN is offline   Reply With Quote
Old 09-16-2008, 10:30 AM   #5
justcuz
justcuz's Avatar
See the little tab on the thermostat housing? That is were the return spring for the throttle goes from the factory. There was also a little L shaped bracket that you could bolt on the housing. Lots of clean ways to do it, mostly depends on spring length and your accessories.
justcuz is offline   Reply With Quote
Old 09-16-2008, 10:41 PM   #6
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I dont have a good pic, but I used all Lokar stuff (Kickdown, throttle peddle, bracket with springs, and Throttle cable).
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
