Old 09-06-2008, 08:15 PM   #1
hrc200x
what year tach gauges are these? Also radiator bracket help
What year are these 3 tach gauge clusters from? The newer one I put a 85 mph speedo in it, it had a 100mph one which I knew wasn't right. I also put in a temp gauge that had the numbers rather than H and C. But I do think the H and C gauge that came out of it was the correct font/writing as the other gauges.
The two older ones are both mechanical oil pressure.
Also is a picture of a problem I ran into trying to install the radiator. Came out blurry where the problem is so I'll try to explain. The rubber that fits in the bracket hits the front main radiator support thing before the bracket itself tightens down with the 2 bolts. You can see the rubber is sticking out further than the mounting surface of the bracket. If I cut the back of the rubber off it might work, but would like to do it right. It might be rubber from a 70s model if they were different? Or the brackets could be a little short if there were different ones of them?
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 09-06-2008, 08:37 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: what year tach gauges are these? Also radiator bracket help
The yellow one is a 73-74 model with an amp gauge. The lense free one is no newer than an 83 (Last year I believe) and the other one I couldn't tell without seeing the back side
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-06-2008, 09:57 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
This one looks to be a 77+ cluster. It has Volts rather than AMPS, but you said it was mechanical oil pressure. I believe that ended in 77, so it might be 77 only.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-07-2008, 02:21 AM   #4
Prong
The yellow is 73-75 (Amp gauge is a giveaway). The top one should be a 76 (single warning lamps in the tach/speedo area--77's have dual warning lights). And the last one is 81+.
Prong is offline   Reply With Quote
Old 09-07-2008, 08:10 AM   #5
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The newest one could also be an 80, that's when they changed the script. The gas gage without "unleaded fuel only" makes it even less common. It must have come from a non-emissions truck.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 09-07-2008, 09:22 AM   #6
hrc200x
Thanks for the help. Is it also true that using a amp gauge cluster in a truck designed for volt gauge can cause damage? Or is it vice versa?
If I remember right the yellow one came out of a Gentleman Jim. I see by ElGracho's sig that his is a '75 so that would be right.
The newest one came out of a '80 1 ton 4x4 diesel. The tach was covered poorly by electrical tape, but I belive the tach harness was partially in tact. I don't think diesels ever came with tachs, and if they did redline wouldn't be 5000 rpm.
Any ideas on the radiator bracket?
Old 09-07-2008, 10:25 AM   #7
Dooley
Dooley's Avatar
The diesel was only available in the C10 in 1980.
Dooley is offline   Reply With Quote
Old 09-07-2008, 04:16 PM   #8
Prong
The diesel tachs (very rare BTW) that I've seen only went to 4K.
Old 09-07-2008, 08:30 PM   #9
hrc200x
Where does the factory wiring harness for a tach get power? There is a plug in on it that looks like it should clip into the fuse box but none of the alignment tab things are in the correct place to plug in. After that plug in there is about 3 inches of wire, then another plug in, female end I guess.
Old 09-08-2008, 02:43 AM   #10
Prong
One of my 79's came with the tach from the factory and it has one of those fancy factory terminals that plugs in to the fusebox. On my other truck that I put the tach in, I just used a nice spade terminal to an ignition hot terminal on the fusebox. The truck is in a million pieces at the bodyshop right now, so I can't get a pic for you too soon. BTW, you WILL fry wiring if you plug a Volt gauge cluster into an Amp wired truck and vice versa.
Old 09-08-2008, 05:42 PM   #11
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
73-75 is the yellow one
76-77 is the black with the lense (mechanical oil)
80-81 is the new script one without a lense.
As for the radiator support, what year truck are you working on and where did the brackets and radiator come from. It looks to be the wrong isolators...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-08-2008, 09:32 PM   #12
hrc200x
I'm surprised chevy even made it so you could plug a volt cluster into a amp wiring harness and versa vice.
My one tach harness does have the factory plug in, it just doesn't have the correct alignment tabs to fit into the fuse box or the box doesn't have the correct ones to accept it. I'll try to get a pic sometime.
The clip is a '88. Brackets I'm not sure what year, guessing a 80s with out A/C? Didn't the non A/C trucks have the lower radiator? Rubber pieces might have come from a 70s, radiator I belive is a 70s. I have rubbers from a 80s, and the back of them that is getting pinched in the picture doesn't happen on the 80s ones, but they don't span enough to reach accross the radiator to hold it. Maybe these rubber pieces along with the brackets changed from 2 to 3 to 4 core radiators.
Old 09-08-2008, 11:03 PM   #13
ElGracho
ElGracho's Avatar
...The clip is a '88. Brackets I'm not sure what year, guessing a 80s with out A/C? Didn't the non A/C trucks have the lower radiator? Rubber pieces might have come from a 70s, radiator I belive is a 70s. I have rubbers from a 80s, and the back of them that is getting pinched in the picture doesn't happen on the 80s ones, but they don't span enough to reach accross the radiator to hold it. Maybe these rubber pieces along with the brackets changed from 2 to 3 to 4 core radiators...
With the mix and match on parts, I'm not surprised you are having problems. The 73-80 and 81-87(or 91 burb/blazer/crew cab) radiators are different.
For just 81-87 there are at least 5 different radiators/upper bracket combos. 6 cyl small/narrow radiator, the standard small block v8 radiator (deep dish on the upper fan shroud), HD cooling small block v8 radiator (shallow dish on upper fan shroud), big block v8 radiator (no dish on upper fan shroud, wide flat top bracket, and the diesel radiator (super wide by super tall).
To make it fit right you'll have to get a late radiator and the brackets and fan shroud that match.
Joe
Old 09-11-2008, 08:20 PM   #14
hrc200x
Is there a how to on resetting the odometer, preferably with pics? I found one, but it didn't say what year its for, the guy that wrote it signature said he had a '72. Is it the same as older models?
