Old 09-07-2008, 01:12 AM   #1
crazyred
yeeha
crazyred's Avatar
alt. bracket problems
hey guys i got a 69 GMC 1/2t with a 350engine and im having major problems finding the proper bracket to hold the stock type alt. it seems all of the after market brackets dont have enough slot to tighten the belt up .. in other words the smallest belt needs pry bars to get it on the pullies but i run out of slot to tighten the belt
before i rebuilt the eng i had the bottem of the alt bolted to the side of the ram horn exaust manifold. Now i have headers and the lower bracket (alt to header) was not working with the stock upper alt bracket so i tryed two different upper alt (after market) ones and another after market lower one
Nothing seems too work... so what am i doing wrong ... can you help me out and show me some pics of you alt setup !!!
thanks
1969 GMC 910 97% rust free
2002 olds Alero
1986 New Yorker 4dr ... the new DD...My POS car... dude its got a turbo!!!
Don't drink and drive, you might spill something!!!
Daryl Kuchmak
crazyred is offline   Reply With Quote
Old 09-07-2008, 01:41 AM   #2
El Jay
Gone to greener pastures
Re: alt. bracket problems
Sorry, but I don't have any pictures.
When my son & I pulled the 292 and put a 350 in my '69 (was his @ the time), we took the alternator bracket set up off a '76 GMC/350.
The "slider" is a big bracket that bolts to the water pump and intake manifold.
The "pivot" bracket bolts to the water pump and to the cylinder head. The bolt to the head is about 6"-6 12" long and goes through a VERY long spacer.
It was a direct bolt on and has caused no problems in the last, oooooh, maybe 10 years, or so.
I also need to add that this moves the alternator to the right (passenger side) of the engine.
When I need a new belt I either take the # off the old 1, or specify "'76 GMC, with a 350."
Never a problem getting a replacement belt, or with the adjustment. The bolt on the "slider" is just about the middle of the slot.
I hope that helped you a little bit.
Enjoy what's left of your weekend.
El Jay
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 09-07-2008, 05:04 AM   #3
JimKshortstep4x4
Here is a pic of a stock 71 setup which would be like the 69.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-07-2008, 02:06 PM   #4
Senator350
Senator350's Avatar
it's pretty easy to just measure the length of belt you need and ask for that specific length at your local parts store.
should be your easiest fix
RN U OVR
Senator350 is offline   Reply With Quote
Old 09-07-2008, 09:14 PM   #5
100%Chevy
Wink Re: alt. bracket problems
Jim,can you tell me what the color of your truck is?I know it's blue,but what did G.M. call it?
The reason I ask is because in 1971 I had my 57 Chevy painted that color.The bodyman just called the dealer and got the code for the paint.
I've been thinking about painting my current 57 that color again.
Thanks,Mike.
100%Chevy is offline   Reply With Quote
