09-07-2008, 01:47 AM | #1 |
78 Big10 454
Rear End Gear Ratio
My P/U has a 2.73 posi rear end. I need you, the experts, to recommend a good rear end gear ratio for highway cruising. Any help is greatly appreciated!
09-07-2008, 03:09 AM | #2 |
Re: Rear End Gear Ratio
I'm by no means an expert, but I'm sure they will need a little more info. Like total wheel/tire diameter and what transmission you're running.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
09-07-2008, 03:25 AM | #3 |
In the Forgotten far North.
The lower the number the higher the gear ratio is. Thusly if you want good highway cruising gears your 2:73's are a real good set as is. Unless that's a typo and you meant 3:73's instead. Then yeah I'd have to say get some lower number'd gears like 2:91 - 3;07's You'll also have to re-gear your speedometer gearing to match otherwise your speedo's gonna read wrong
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
09-08-2008, 06:11 PM | #4 |
www.73-87chevytrucks.com
3.42 is about the best you can get for a compromise of good acceleration and cruise speed.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-08-2008, 06:52 PM | #5 |
Slugish
Ditto to captkaos- best of both worlds 3:42 for a 3 speed trans
3:73 for an overdrive 4 speed Of course extreme tire height differences from stock will have an effect on this as well. In other words if you are running a 31-332 in rear tire , you will be ok with a 3.73 in a3 speed trans. |
09-08-2008, 08:14 PM | #6 |
78 Big10 454
Many thanks to all of your replies. I have a great deal of respect for the participants of this board. You're the greatest!
09-08-2008, 08:26 PM | #7 |
Happy to be here
Since you didn't provide any more details, I'll surmise by your screen name that we are talking about a big block powered truck. With that piece of information, I will assume you are running a TH400. Based on that theory, I would suggest a 3.08 if you want optimal mileage, and a 3.42 is you are willing to sacrifice 1-2 mpg for some additional torque.
09-09-2008, 04:49 PM | #8 |
Parts and more parts
What do you have for tire size and tranny in the truck? This info will support a calculation of RPMs on the highway. My guess is the 2.73 is killing you on the hills and the city.
09-09-2008, 07:27 PM | #9 |
With a 28" tire, 3.42's are an awesome gear for mixed city and highway driving.
However, if you have to do long highway trips, in the order of several hours on a regular basis, then your RPM's are going to be a bit uncomfortable on the highway. I would recommend 3.42's if you only have to do a few miles of highway driving a day. If you do a lot of long highway trips, the 2.73's are probably the best thing for you if you want to keep RPM's down. You really can't expect them to be fun or accelerate quickly though. If you want the best of both worlds, then you need an overdrive transmission.
1977 GMC Sierra Grande |
09-09-2008, 09:46 PM | #10 |
Do you use your cruise control, and do you have hills that you drive in, where you live? The 3.42 or a 3.73 will give you a good pull in the hills and the cruise will not kick down as much as it would on a 3.08 gear or higher. I talk from experience, I had a 3.42 gear in my truck and changed it to the 3.73 to get the acceleration on the street. I run at 2500 RPM at 70 MPH with an OD tranny. If that were a standard auto it would be about 300 to 400 RPMs higher. My DD truck (91 Silverado) runs at 2200 RPM with an OD tranny and 3.42 gears (both trucks have 28" tires on the rear).
01-18-2009, 04:38 AM | #11 |
HI, i don't know if you can help me or not,but i have a 1972 International harvester 1210 p/u(3/4 ton) and i have no idea on what the rear gear ratio is. Can you help me out?
01-18-2009, 08:42 AM | #12 | |
The other thing to look at is the carrier. Depending on which rear end (10 or 12 bolt) is under your truck, the normal gear set carrier change is at 3.23 or 3.43. This may involve swapping out your carrier (ie the posi unit) to get the lower gears. Often you can get a gear set that avoids this by using a spacer to correct the ring gear position, but they are not as strong as the correct carrier. Might want to check Summit for the available selection.
You must be a subscribing member to offer to buy parts. Copied from the rules: Quote:
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors Last edited by LONGHAIR; 01-18-2009 at 11:14 AM. |
01-18-2009, 10:33 AM | #13 |
One shot, one kill.
I run 3.08 gears, 31" tires and a rock crusher 4 speed. I'm turning about 2200 RPM at 70. The eng is a 350 with a quad and I get about 17 mpg. I like the 3.08 gear set. If I need power I got that real low 1st gear as well as deeper reduction going into 4wheel low range, and the lower ratio gives decent fuel economy. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
01-18-2009, 10:39 AM | #14 |
One shot, one kill.
tecky, isn't there an International board? Well anyways, gears is gears. Do this, count the teeth on the pinion gear, count the teeth on the ring gear. Divide the ring by the pinion and thats the ratio. Example, pinion gear, 15 teeth, ring gear, 41 teeth. Divide 41 by 15 and you get 2:73. Make sense to you?? jim
01-18-2009, 11:20 AM | #15 | ||
A muncie (M-22 rock crusher) is a high geared close ratio car transmission with a 2.20-1 first gear. IMO they would suck in a big heavy truck in the first place, but I have never heard of anyone adapting one to a 4x4?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
01-18-2009, 11:29 AM | #16 |
I have a 10 bolte full floating rear. But I don't think it is a posi rear . How would I fins this out? I also need all 4 drums can anyone tell me where I can get them without spending a fortune on them? Any help would be appreciated
01-18-2009, 11:40 AM | #17 | |||
However it is against the rules to post a "want to buy" messege. Quote:
01-18-2009, 06:48 PM | #18 |
One shot, one kill.
Long hair. I think there is a mix up in terms. We all up here call the 117MM a rock crusher. I think you all refer to it as a 465?? Whenever I went to parts they wanted it in MM. Hope that clears it up. jim
01-20-2009, 12:25 AM | #19 |
OutOfMyMind & I'llNeverKnowWhy
I have 3.42s and 29" tires and when you get out on the highway where its a 75mph limit, it really has the engine revved. For lots of highway the 2.73 should be good.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
01-20-2009, 06:25 PM | #20 | |
What do you consider having the engine really revved? My truck at 75 MPH with a 28 " tire, a 700R4 tranny and 3.42 gears runs round 2200 RPM Right where my power band is the best. Do you have an OD tranny? |
01-22-2009, 01:36 AM | #21 |
Little above 3000RPM. I have a TH350 so 3rd is 1:1. With a 700r4 in OD its .7 so its 30% less, plus you have the tc lockup. I'm looking into a 700r4 swap someday.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! Last edited by Justins76; 01-22-2009 at 01:37 AM. |
01-22-2009, 02:21 AM | #22 |
Go to the Binder Bulletin.com, they specialize in International trucks and can give you better answers.
04-01-2009, 01:12 AM | #23 |
I just bought a 1972 C1500 and discovered it has an SM465 in it and man Does this engine rev on the highway!!! I have a 69 chassis with a 350ci and th400. How much is involved in swapping this out. Ie crossmembers, driveshafts etc? Not really ready to do swap right now any thoughts on maybe gear ratio change, like 273'3 or higher?
05-04-2009, 12:57 PM | #24 |
I used to have a truck with 2:73 gears and man it got great gas mileage!
05-05-2009, 07:03 AM | #25 |
Some of the Big 10's had 3:40 rear, 12 bolt. I have one I put in my '85 out of a Big 10. I counted it three times , 10 and 34 teeth.
