Muncie 4 speed out of a car?
will a bellhousing out of a 69 chevy p/u work on a car 4 speed tranny? The truck has a three on the tree, and what all brackets will work?
Re: Muncie 4 speed out of a car?
Man,you won`t believe what a bolt-in a Muncie M20/21 is in place of the Saginaw 3 spd that`s in your truck.Bolts right in!
I`m using an M22,which has a fine tooth input.Had to buy a clutch for the spline count.I`m also using the automatic crossmember and mounting the tail of the transmission there instead of the 3 spd bellhousing w/mounts.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
It will bolt right in. Just make sure you get the linkage kit for a Muncie.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
laying low
![]() Join Date: Mar 2001
Oh man. Chevy was great about that. I broke the 3 speed in my 78 pkup and already had an M22 I was saving so I swapped them out. I had it in the shop and back out in under 2 1/2 hrs. Amazing that the splines were all the same, yokes included. What a breeze.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Be sure to check the bore of the bell housing where the transmissions pilot. Truck bell housings have a larger hole and you will need an adapter.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks for all the info. greatly appreciated!!!
