Drop Spindles Wont Align
So I just put my drop spindles on from ECE with all new ball joints and tie rod ends, but when i took it to get aligned the guy said he couldnt get the camber just the way he wanted it because the bolts going through the frame and into the upper A-arm were not long enough and he ran out of adjustment before he got the camber where it should be. I know this guy very well and he has been aligning cars for 40 years so hes not filling me full of crap and i looked underneath and there is not many threads left showing through the nuts. Has anybody else had this problem? Can i replace the bolts or do i contact ECE? Thanks in advance.
![]() ![]() Join Date: Jul 2002
Re: Drop Spindles Wont Align
I have heard that from others who dropped theirs also. I know they make longer bolts just for that, I just can't remember who. Hopefully the others in the know will chime in soon.
laying low
![]() Join Date: Mar 2001
From what I've heard normally installing just the lowered spindles there is no alignment probs. It's when 3" or more drop front springs are used that the alignment issue pops up. That is unless there is a bent frame or suspension parts.
I believe there are offset upper control arm shafts available but I forget who sells them. I'm sure someone else will pop in with that.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Aug 2003
I've never had that problem and have several lowered 4" in front using ECE parts.
67-72 parts collector,…
![]() Join Date: Nov 2002
I just installed CPP tubular upper arms to solve this very problem. 3" of drop spring and 2.5" of spindle. Longer upper bolts would definitely be cheaper.
It was aligned before the install and everything was fine. I replaced the stock springs with new stock height units. Anybody know where i can get longer bolts and how hard they are to install? I havent really looked at it that hard as i was pretty pissed when i spent all that money and it didnt work out.
I think I would find a new alignment guy. Installing spindles doesn't change much. It's the use of drop springs (3" for sure) that screw with the camber/caster issues. Has the truck been wrecked? Bent frame maybe?
Spindle won't change camber. The problem is with the springs you replaced.
Mike Redpath |
Like i said it aligned fine before so i doubt the frame is bent. If the frame was bent i dont see how it would happen on both sides in the same manner. Ive had this guy align a lot of cars for me and hes been doin it for 40 years. I can tell the top of the tire is tipped in and theres not much thread left showing on these bolts to adjust it anymore. Nobody else has ran into this?
#10 | |
So i should try a different set of springs and it should resolve the issue?
Active Member
Is this something I'm going to run into with ECE dropped spindles and bags?
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
#13 |
#14 |
He may be a really good alignment guy with stock vehicles ...but does he have a lot of experience with lowered vehicles?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
#15 | |
71stub, are you using the same exact springs that were in place for the last alignment?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-07-2008 at 11:41 PM. |
#16 |
big guy
![]() Join Date: Jun 2008
Hey lolife99
i am looking to install the same setup you just did. (I just installed CPP tubular upper arms to solve this very problem. 3" of drop spring and 2.5" of spindle.) was it worth it? i am going to need the lower A arms as well $$$$$ thanks Ray __________________ |
#17 |
No, I used new springs and it seems to sit lower than the 2.5" i was expecting. I think i will order another set of springs and see what happens. Thanks for all the help.
#18 |
You should have gotten 2.5" of drop from the dropped spindles alone. Try putting the stock springs back in. If it's not low enough for you, trim 1 coil off the springs.
#19 |
![]() Join Date: Apr 2008
They may have sent you the wrong springs.If you are put of adjustment on the control arm bolts its not your alignment guy.
#20 |
Old Skool Club
![]() Join Date: Jun 2001
I have had no problems with my ECE stuff. The alignment went to stock specs. We did replace the upper/lower control arm shafts and bushings, as well as the upper/lower ball joints, idler arm and pitman arm, as well as the outer tie rod ends and the center link.
But, the bottom line is that the specs went back to O.E.M. specs and it drives great.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#21 |
![]() Join Date: Jan 2000
Check the springs. I had no problems with my dropped spindles either.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
#22 |
67-72 Addict!
70GMCer had a similar problem and posted about the tie rod adjusting sleeves or something being installed backwards causing this on his. Do a search and hopefully that will help.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 09-08-2008 at 10:30 AM. |
#23 | |
![]() Join Date: Nov 2004
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#24 |
I feel the need to chime in here...I just did the ESE 4/5 drop and had no problems. 2 1/2 dropped spindles with 1 1/2 springs on the front.They told me to align to factory specs..which it did no problem. Like everyone else has said it is the springs that create the need for alignment. I also found the guys at ESC to be MORE than helpful when I was doing my install. I was concerned whether or not the 5 inch drop springs in the rear would look the way I wanted..Mark told me if I paid the shipping they would swap the springs out for 6 inchers...hope this helps ...Steve
#25 | |
