09-07-2008, 07:50 PM | #1 |
4x4 big block exhaust
I'm building a 1968 half ton 4x4 with a manual trans, put a new 454 in it and now I'm stuck! Anyone know what exhaust manifold/header will fit on the drivers side? Thanks for any help you can give!
09-07-2008, 11:40 PM | #2 |
Re: 4x4 big block exhaust
you have to trim the frame. Doug Thorley makes headers that fit.
09-08-2008, 10:42 AM | #3 |
Post Whore
I used some Dynomax headers that you can find more info about in the link to my website in my sig - however, they will not work for you since you will be using stock clutch linkage. Just posting this info so you can avoid them.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-08-2008, 11:13 AM | #4 |
I use hooker super comp headers in all of mine and never had to do any trimming.
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
09-08-2008, 03:54 PM | #5 |
Junior Member
I agree with the hooker recommendation, its been a while but I used them on a 69 sub with a bb and a 4-speed.
09-08-2008, 04:10 PM | #6 |
If you convert to Hydro Clutch you can run the heder of your choice
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
09-08-2008, 05:28 PM | #7 |
Windy Corner of a Dirty Street
Meh, I wouldn’t use headers on my truck if they were growing on my a**. I used headers on two trucks and they cured me for life! On a stock engine headers are only good for ruining starter motors and the catalyst of tons of exhaust leaks.
I am aware the engine sits back pretty far on the 67-72 4x4’s compared to my ’78 but I had the same issue with finding an exhaust manifold to clear the mechanical clutch linkage when I did my BB swap. I ended up using a driver’s side exhaust manifold for a 1973 – 1984 truck, which cleared the clutch linkage just fine……After all, that era manifold was designed to clear that stuff. I would think the 1973 – 1984 manifold would fit 67-72 4x4 with a BB crammed in it just fine as well. Here is a picture of my ’78 with a Vortec 8.1L. The 8.1L physically bolts in the same as any BB so I am still running my old 454 exhaust manifolds. Maybe these pictures will help determine if this era manifold will fit a 67-72.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
