Old 11-17-2002, 03:14 PM   #1
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Question no taillights, brake lights, dash lights???
I have an interesting situation. I have no dash lights, running lights or brake lights. I switched the headlight switch...not it... and I already had headlights. the flashers work but I don't have turn signals? the brake light switch is functioning properly... but isn't getting power? where do you think my problem is??
Suicide-D is offline   Reply With Quote
Old 11-17-2002, 03:34 PM   #2
Piston
Piston's Avatar
Have you double checked fuses? Rotate the fuses, there could be a corrosion problem.
If the brake light switch doesnt have power on one terminal, you have a wiring problem from the fuse block (assuming the fuse is good) to the switch. Find out why you have no power to this switch!
I would start with that circuit first, its the easiest to trace and could lead you the problem thats causing all of it.
Piston is offline   Reply With Quote
Old 11-17-2002, 06:24 PM   #3
Suicide-D
correction....
I have turn signals and there is power to the stoplight switch. I have checked all the fuses they are fine. I removed the fuse block to check behind it... looks ok. I removed the junction block on the firewall... no corrosion. I followed the white wire coming out of the stoplight switch up to the half circle connector behind the dash. this goes to the turn signal crap in the column... right? I'm getting a little frustrated... so I'm going to stop and pick up tomorrow. any ideas?
Old 11-17-2002, 06:28 PM   #4
cableguy0
check all of your grounds . bad grounds can cause some pretty weird things to happen.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-17-2002, 06:34 PM   #5
Piston
Piston's Avatar
If the turn signal switch is bad, you could loose brake lights, tail lights and turn signals.
If you have a good switched power coming from the stop light switch, follow that as far as you can into the turn signal switch.
Make sure there's power as far as you can check it. Next check the green and blue (I believe), these are your stop/turn signal wires coming out of the turn signal switch, do they have power when you press on the brake? If you know there's power going in and nothing coming out, the T/S switch is bad.
Old 11-17-2002, 06:56 PM   #6
6772king
6772king's Avatar
had this problem also and it was the pink and red wire on the back side of the fuse block (the inside part behind the plastic cover that toches the inside fire wall) make sure that the connection is good with a test light i just had to clean up the conection and it was fine hope that works for ya
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 11-19-2002, 10:40 AM   #7
Erl
Erl's Avatar
Hey DD,
Had some of these same problems and replaced my turn signal mechanism. Fixed all my problems. When are you sending the thermo housing back? No hurry just wondering.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
