Old 09-07-2008, 10:59 PM   #1
texastrendz
straight trailing arms
has anyone tried to make a set of trailing arms that are straight at the axle instead of the built in offset at the spring, i am bagging my c-10 and it will have a pretty low ride height. i was wondering if someone has made the arms straight to compensate for pinion angle. any help would be great guys.
texastrendz is offline   Reply With Quote
Old 09-07-2008, 11:09 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: straight trailing arms
I have often wondered that too
I think it would change the pinion angle, but Im not sure that would be a bad thing being really low ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-07-2008, 11:18 PM   #3
mr48chev
mr48chev's Avatar
There are wedged spacers available or you could make a pair.
The circle burners come through again http://www.heintzperformance.com/home.php?cat=419 You would need to know what angle you need before ordering though.
Also I'd call and ask if they do indeed fit the stock truck arms. I didn't see anything that gave the exact measurements but it appears that they are 3-1/2 inches between the u bolt slots.
Old 09-09-2008, 11:08 PM   #4
texastrendz
bump bump
Old 09-10-2008, 11:02 AM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I think the worst you would have to do is cut the welds & rotate the axle to the correct pinion angle
But I wonder if making the arms strait would let you go as low
There is a point where if you go low enough that the arms come in contact with the frame & with that kick up it may help to make the axle go higher
Im not sure, just thinking out loud again
Sinister
Killer
Old 09-10-2008, 02:12 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
I've seen it done with straight arms made out of box tubing. Also ECE sells the new axle pads for the 67-72 style rearend. I'd say cut off the old axle pads and install new ones at the correct pinion angle and you should be fine. The truck I saw had a reworked 2"x4" box tube frame with a big notch,... so I don't know how much interference you will get with a stock frame.
Keith
Convert to disc brakes.
