Old 09-08-2008, 01:00 AM   #1
ColinOpseth
bbc swap in 69 frame
Hey guys,
I have a '72 shortbed cab and bed on a '69 frame. I've done the front spindle swap already but I want to put a '76 3/4 tone camper special 454/turbo 400 in that truck. Can I use the frame stands/perches and motor mounts from the '76 in that truck?
I'm sure the springs won't be strong enough but that's OK because long-term I am going to bag it anyway. They'll hold up well for now.
My main question surrounds the perches. Which perches will I need to run that 454 in a '69 shortbed frame?
Thanks,
Colin
Webmaster: www.h-body.org
ColinOpseth is offline   Reply With Quote
Old 09-08-2008, 12:45 PM   #2
Luvlegs
Luvlegs's Avatar
Re: bbc swap in 69 frame
I've seen everybody say you can use just about any mounts it seems.. 'cept the 250 and 292's.. - I believe the 73 and up will work with a bit of hole wallowing and maybe drilling one more. There's a ton of threads it seems if you do a search on it. I'm using a set of 72 only BBC mounts (clam shells) to put my 454 in my 72. I've also seen a 572 mounted on just regular BBC stands in a shorty 67...
I'm sure others will chime in but in the meantime, do a search for "BB mounts 73".... that should get ya started.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 09-08-2008, 07:57 PM   #3
ColinOpseth
Thanks,
I appreciate it!
Take care,
Colin
Old 09-08-2008, 09:04 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the 73 - 87 frame mounts are a bit taller than the 67 - 72 frame, but it can be done. I placed washers between the frame and mount, and if I remember right, I may have had to cinch the mounts down a tad.
