Old 09-08-2008, 08:05 AM   #1
Turbo85GMC
Turbo85GMC's Avatar
Upper Control Arm Mounting Thread Size
Does anyone know the thread size on the studs that hold the upper control arm to the frame? I needed an impact wrench to get the nuts off because the threads were so rusty. I want to clean up the threads on the studs and nuts so that I can get a good clean reading on the torque wrench when I re-install everything.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 09-09-2008, 09:16 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Upper Control Arm Mounting Thread Size
Anyone out there have an answer?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-09-2008, 10:33 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I would not clean them off too much. I brushed mine and reinstalled them. Tight them snuggly. When you get a front end alignment, they'll torque them for you.
Check here http://www.torkspec.com/torkspec.aspx
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-09-2008, 11:43 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
i believe they are 1/2-20 I will check Wednesday.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-10-2008, 06:50 AM   #5
Turbo85GMC
Turbo85GMC's Avatar
Thanks for the feedback!
'85 GMC 1500
