09-08-2008, 09:02 AM | #1 |
Sender unit for chevy 350
Hi folks,
Iv'e got a very nice 1957 stepside. It has the original dash cluster, however a 1975 chevy 350 enginge. Sadly it doesnīt have a temp Sender. I have trouble locating a corresponding hole in the manifold for that. Q: does anyone know where the temp sender should be located? Q: does anyone know what sender (range) will work with my heat gauge? It is a spreadbore 4/bbl cast iron manifold, truck engine, 1975. The only in/outs I see is, water heat for the fan, oil and vacuum. Take care //B |
09-08-2008, 10:02 AM | #2 |
polishing a turd
Re: Sender unit for chevy 350
a pic would help, but there is often a port next to the thermostat housing on the intake
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
09-08-2008, 10:42 AM | #3 |
You should have a plug on the heads, use that hole.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
09-09-2008, 01:10 AM | #4 |
Hi
looking a little bit closer I did find just under the thermostat housing (on the block)a plug. Hard to see, but maybe a 1/4 or 5/8 hole. I will try to use that one. I didnīt see any other holes on the heads, or anywere else. Does anyone know if the standard 75 chevy sender works with the original gauge? //B |
09-09-2008, 10:17 AM | #5 |
Look between the spark plugs on the pass. side between # 6 and #8 plug for a pipe plug, remove and replace with sending unit of choice.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-10-2008, 01:41 PM | #6 |
Yep, I found the plug!
Bought me a sender , TS-6 made by standard. I tested it and it seems to be working just fine with my old gauge. Now I have all my guages and the speedo working too. Thanks a bunch. //B |
