Old 09-08-2008, 05:58 PM   #1
baddiesel
Chevy Truck frame(s)
I know this will sound like a dumb question, but I'll ask y'all & hang my head in shame. Is a 1971 Chevy C20 frame and a 1986 GMC 1500 (short bed) basically the same? I'm more concerned about width, not so much length. I'm attempting to put a 1971 body on a 1986 frame. I appreciate your info.....Thanx in advance.
baddiesel is offline   Reply With Quote
Old 09-08-2008, 07:40 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Chevy Truck frame(s)
Is the 86 a C20?
Is the 71 a short bed?
If so then yes they are "basically" the same.
And I use "basically" lightly.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-08-2008, 07:52 PM   #3
baddiesel
The 1971 C20 is a long bed, and the 1986 1500 is a short bed. The reason I'm not so concerned about the bed length, is because I plan to install a stepside or fleetside shortbed on the '86 frame. I am concerned with the radiator support braket fitment/fender/cab fitment (eg width & length). Thanx for your response.
Old 09-08-2008, 08:14 PM   #4
Sammy
If your worried about width. Yes they are different. Thats why the 86's had inside frame mounted gas tanks. Imagine the core supports/cab mounting would be different but that could be redrilled. If I'm wrong someone will tell us.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-08-2008, 08:25 PM   #5
90\87Formula
90\87Formula's Avatar
Check these two links. They have some of the dimensions.
http://67-72chevytrucks.com/vboard/s...d.php?t=180770
and
http://www.chuckschevytruckpages.com/framespecs.html
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 09-08-2008, 08:28 PM   #6
baddiesel
Thank you Sammy. I feel certain there will be radiator support bracket issues. I thought about fabricating & welding steel tabs in order to implement this installation. The '86 frame is very clean & corrosion free!
Old 09-08-2008, 08:47 PM   #7
baddiesel
Thanks 90/87 Formula. I was not able to save/print the jpegs from chucks chevy truck pages. I was trying to locate the specs on the '86 frame to make a comparison. Thank you again for the great info!!
Old 09-08-2008, 08:53 PM   #8
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yes they are different, the radiator support brackets are mounted in a different position, cab mounts are different and the bed mounts different.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-08-2008, 08:59 PM   #9
Firefighter
Talk to Mudder he has done this with his truck.
Yellville, Ar. USA
Old 09-08-2008, 09:00 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
this is a swap that basicly will not work. The 67 - 72 frame is flat. The 73 - 87 frame is not flat.
A 4X4 you can make work by modifying the wheel base, and then making a custom body lift to make the cab sit as high as the bed. But a 2 wheel drive will look retarded with a body lift.
Not to mention you have a 131 inch wheel base frame that you wanna put a 115 inch wheelbase truck onto.
Also, a comment up there, the fuel tank is not between the frame rails on an 86, it is the side mounted one that got lotsa wrong publicity about 10 years ago of so.
Old 09-08-2008, 09:15 PM   #11
baddiesel
Mr. Longhorn Man, I appreciate your info. My '86 is a 4x4 with 1 ton running gear through out. I believe you're 100% correct regarding the elevation aspect, this is going to be a tough, and very complex swap due to non-similarities of the frame. I can fab/weld cab mounts inboard or outboard. I'm having the most difficult time with the measurement and fitment of the distance from the radiator core support through the fenders, to the cab itself. That's a rascal to pinpoint exact placement & proper fit to make it look correct.
Old 09-08-2008, 09:19 PM   #12
Firefighter
Talking Re: Chevy Truck frame(s)
Like I said PM Mudder on this he has pics and the info on how to do it, he gave me the info on it before my computer went to pot.....
Yellville, Ar. USA
Old 09-08-2008, 09:25 PM   #13
baddiesel
Thanks Black & Blue. I'll go to the member's list and PM him.
Old 09-08-2008, 09:42 PM   #14
Longhorn Man
I never noticed it was a 4X4... my bad.
Old 09-08-2008, 09:57 PM   #15
baddiesel
I wasn't specific regarding what was what. I have a 1971 C20 body that I'm "renovating", and I want to install it on my '86 GMC frame. It has all the goodies in the driveline that I like, except it's very thirsty. I love my '71, just prefer my 1970 454 V-8 eng, built 700R4, NP-205 twin-stick, dana 60 front w/EZ locker, 14 bolt rear w/detroit locker. My '86 won't pass North Carolina's smog/safety inspection. But, with the '71 body mounted on top of that frame & driveline, it becomes exempt from inspections. I'm starting to think this is not feasable. I've worn-out a tape measure trying to analyze the fitment.
Old 09-08-2008, 10:08 PM   #16
Firefighter
No problem, anytime!!!!!!!!!!!!!
Yellville, Ar. USA
Old 09-08-2008, 10:44 PM   #17
Mudder
Mudder's Avatar
It's not a big deal at all.. I will email you the info in the morning after you pm me your email addy.
Mudder is offline   Reply With Quote
Old 09-08-2008, 10:56 PM   #18
72 CustomCamper
huh ???
72 CustomCamper's Avatar
73-87 had OUTSIDE the frame fuel tanks. 88-up they were moved inside the frame...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-08-2008, 11:02 PM   #19
og350
og350's Avatar
if you need some more pictures my "redneck" neighbor put a 70 body on a 76 2wd frame and then made it a 4x4. it works but yes the front rad support mountis different and the rear cab mount had to be moved. i dont like how much gap is between the cab and frame. why not just use the 70c20 frame you have and make it a 4x4?
good luck!!
og350 is offline   Reply With Quote
Old 09-09-2008, 01:05 AM   #20
Dooley
Dooley's Avatar
The 87-91 R and V model pickups and chassis cabs had the fuel tanks outside the frame rails.
Dooley is offline   Reply With Quote
Old 09-09-2008, 08:00 AM   #21
baddiesel
Mr. OG350, I believe it will be less work to fabricate & move sheet metal, than to modify & relocate an entire drive train that is already operational and in-place. My '86 GMC short bed also has a roll cage and rock sliders installed, along with a 14,000 lb winch on the front. If I could just relocate the radiator support, front fenders, hood & cab onto the '86 frame, I would be soooooo happy. I would also install a new wiring harness from scratch (custom marine grade w/breaker switches).
Old 09-09-2008, 08:20 AM   #22
Mudder
Mudder's Avatar
Your information is on the way.
Old 09-09-2008, 12:12 PM   #23
baddiesel
Mr. Mudder I received your photos. Thank you very much, you've got a PRIMO truck!!!
Old 09-09-2008, 01:53 PM   #24
72 CustomCamper
huh ???
Yes the 87-91 heavy 3/4 and 1 tons still had the tanks outside the frame. The 1/2 and light 3/4 tons had them inside the frame starting in 88. The truck he is asking about is an 86. The person I was correcting was saying that they all had them inside the frame...
Old 09-09-2008, 08:29 PM   #25
Mudder
Mudder's Avatar
As far as tanks go it would be the best to get a Blazer tank from the year frame you have and bolt it in.
