Old 09-09-2008, 08:31 AM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
HEI Troubleshoot
So I am all excited to start my truck and for some reason or another I am not getting spark. I have an accel HEI and I replaced the coil during the recent rebuild. I am getting power to the coil but no spark. How do I trouble shoot the HEI. I did take the coil off last night to check the resistance (I seem to remember as that being the first step in trouble shooting) it had a resistance of 8.6 on the 20K scale. Is it common to have non-functioning coils out of the box? How do I check the module?
Any help would be appreciated, I only have about a month to get this thing on the road before it gets to cold.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 09-09-2008, 09:04 AM   #2
steelhorse
steelhorse's Avatar
Re: HEI Troubleshoot
Did you put the button back under the coil?Is the power going to the right terminal?
steelhorse is offline   Reply With Quote
Old 09-09-2008, 09:23 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
If you take the module to either Auto Zone or O'Reilly's they will check the module for free.
I have never had a coil bad out of the box, but anything is possible.
Make sure the coil is grounded.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-09-2008, 09:31 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Here's the Auto Zone trouble shooting site for HEI. May help you.
Scroll down to the bottom and click on a pic to see the larger print.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
68gmsee is offline   Reply With Quote
Old 09-09-2008, 10:42 AM   #5
JayDubBlazer
go cyclones
I tore it apart and the spring is in there with the button and I had it going to the red wire.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-09-2008, 01:47 PM   #6
Luvlegs
Luvlegs's Avatar
full 12volts right? I know it seems like a rookie thing but going by the KISS standard, had to ask. Changed the resistance type wire that supplied the points with ~9v over to a good 12volts source right?
Possible you put in a new wiring harness that had the points type set up?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 09-09-2008, 02:59 PM   #7
JayDubBlazer
go cyclones
Somebody mentioned that at work, I'm going to check that when I get home. It is a new wiring harness. It does get the full 12 volts with the assy on.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-09-2008, 03:06 PM   #8
Andy4639
Old member
Andy4639's Avatar
It has to get full 12 volts with key trying to crank the motor any drop in the wire will cause a no crank systom. Make sure it's 12 volts no matter what position the key is in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-09-2008, 04:46 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
There is always something that slips up and kicks your butt on these things. I had one that had everything but spark and it turned out to be the pick-up coil UNDER the ignition module. this would require the removal of the dizzy shaft from the housing to change out. The first thing I would look at is the module in the dizzy and BE SURE to use dielectric grease.
piecesparts is offline   Reply With Quote
Old 09-09-2008, 07:47 PM   #10
JimKshortstep4x4
While dielectric grease is good to use on electrical connections it is not recommended that it be used for heat transfer applications. A better grease for use between the module and the distributor housing is a heat transfer grease which is a white grease made specifically for heat transfer. Usually new modules come with the grease.
Heat transfer grease is also referred to as Heat Sink Compound.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-09-2008, 09:31 PM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
X2
seen it happen.....had 12v in run but start was 0v
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-10-2008, 07:26 AM   #12
JayDubBlazer
go cyclones
It has 12 Vdc with acc on, and around 11 Vdc when starting. I also read the painless wire instructions and it said if using a HEI wire the pink wire directly to the coil. I have pulled the module out and took it to Advanced Autoparts. Though it is an Accel module they tested it and it appeared to be non operational. I have purchased another one, but in the process to see if I can check it our myself, just to double check.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-15-2008, 01:51 PM   #13
JayDubBlazer
go cyclones
I have put in the new module and still am not getting any spark. I have 12v through the coil and 12v going into the modulel. I have also tested the distributor and it is properly grounded. I am starting to get at wits end, I am sure it has to be something simple.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-15-2008, 02:01 PM   #14
70rs/ss
70rs/ss's Avatar
IS the 12v during cranking? The reason I ask is that I had it set to acc and it only got 12v on crank, but when i let the key go into run position it had no voltage?
70rs/ss is offline   Reply With Quote
Old 09-15-2008, 02:10 PM   #15
JayDubBlazer
go cyclones
I am getting about 11 vdc when cranking and 12.8 vdc when acc is on
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-15-2008, 02:32 PM   #16
70rs/ss
70rs/ss's Avatar
A pict of the cap and coil might help, but it is dead on right and not 180 out? No spark, as in you have a wire off and spin it over with a plug in it and grounded with no spark?? If so then there is an issue with the module or coil. There is an article in this months Car Craft that mentions there are two coil types for GM hei and they are not interchangeable, maybe you have one of these? Picts might help us to trouble shoot for you??
Old 09-15-2008, 02:47 PM   #17
CPNE
Resident Curmudgeon
CPNE's Avatar
HEI Pickup coil could be bad. Been there, done that.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-15-2008, 05:35 PM   #18
JayDubBlazer
go cyclones
It is an Accel aftermarket HEI model number 59107. Ill see if I can snap a picture. And no I am not getting any spark at the plug. The distributor is aligned with TDC, we took the valve cover off.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-15-2008, 09:11 PM   #19
piecesparts
Agree on the pickup coil, had one do the same thing and I replaced everything---finally this is what solved the problem.
Old 09-16-2008, 07:16 AM   #20
70GMCer
70GMCer's Avatar
Just a thought.....do you have the 12 volt wire plugged into the 12 volt side of the dist. cap, and not into the tachometer side?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-16-2008, 07:23 AM   #21
JayDubBlazer
go cyclones
Yep, and I have 12 vdc going through the coil. I am going to call the Accell tech support this morning and see if they can give me a hand. I did have one thought last night. I replaced the cap and rotor before I put the dizzy back in. I was wondering because I didn't use an Accel brand cap and rotor that I might not be getting any connectivity between the cap and rotor. One more thing to write off the list.
Sorry I wasn't able to get a picture, I will try tonight.
Thanks for all the help
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 09-16-2008, 10:05 AM   #22
kulturekat
kulturekat's Avatar
i was having the same problem justa fewnights ago i replaced just about everything on that hei. what it came down to was somehow one of the wires leading into the cap that hookes to the c b and grd had came loose that hooks to a bolt inside the cap.
also i agree to check on the pickup coil. i would go all the way back through all your connectiuons and look to see if everything is eithe rhooked up correctly or to make sure you dont have any cuts or anything. if all that checks out then id check the pickup coil. i only speak from experience i had a lot of good guys on here help and point me in the right direction.
kulturekat is offline   Reply With Quote
Old 09-16-2008, 10:27 AM   #23
hootz
hootz's Avatar
Check the pickup coil with an ohm meter. You should see between 500 and 1500 ohms when measuring from wire to wire (unplugged from the module) . Be sure to wiggle the wires while testing as the pickup coil moves with the advance and the wires can break but the outside insulation remains intact. You should not measure any resistance at all from either wire to ground. Also take a good look at the rotor. They are bad about allowing current to ground out to the shaft through the rotor itself. Take the rotor off and look at it from the bottom in the middle where it contacts the shaft. If you see any purple discoloration suspect a bad rotor.
Never say Never!!
hootz is offline   Reply With Quote
Old 09-16-2008, 10:27 AM   #24
dznucks
dznucks's Avatar
i have had a similar situation. the ground strap (bent metal strip) inside the cap had broken and i didn't catch it for a few days.
dznucks is offline   Reply With Quote
Old 09-16-2008, 12:41 PM   #25
mrein3
mrein3's Avatar
Back when I was still working in the shop I saw a lot of HEIs come in with one of the pickup coil wires broke. If you look at it it looks fine. Take your little screwdriver and put some side pressure on both of the pickup wires. If one is broke you won't have any spark.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
