Old 09-09-2008, 09:52 AM   #1
D'Animal
Bench Seat Guestion
In my 1967 3/4 Chevy truck I have a stock flip foward bench seat. In my 1972 Chevy C30 and my 1972 GMC 2500 Sierra thay have non-flip forward seat.
I have been looking for a flip forward seat to replace the one in my 72GMC people have been telling me that the 67-72 never came with them. Do I have something Uber Rare in my 67 or am I just not looking hard enough fro a replacement?
D'Animal is offline   Reply With Quote
Old 09-09-2008, 09:56 AM   #2
BlueJeep
BlueJeep's Avatar
Re: Bench Seat Guestion
From the factory, with the gas tank behind the seat why would they have needed to flip forward?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-09-2008, 09:58 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
As close as I can tell from what I have read and seen the seats with the flip forward backs were in the '67 and early '68 trucks.
My '67 has one and it looks to be stock.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-09-2008, 10:12 AM   #4
D'Animal
I will start looking for the 67 bench seat.
I had been looking for the 67-72 vintage seat with no luck on the flip forward feature.
Dan
Danny
Old 09-09-2008, 10:32 AM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
There were 2 "stock" bench seats used. The flip forward kind and the stationary back version referred to as the "full foam" bench seat. I personally have only seen the flip forward variety in 67/68 trucks and have only seen the full foam in 69-72 trucks. That is not to say the full foam could have been an option in 67/68. Both are interchangeable as they use the same seat tracks.
The flip forward seat has minimal padding over the springs. The full foam, as the name implies had a thicjk foam padding over the springs. The seat covers and replacement foam the vendors sell are designed for the full foam seat
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-09-2008, 10:39 AM   #6
bigvinnie
bigvinnie's Avatar
when I put my tank under the bed, I removed the upper bolt on both sides of the outer seat back frame where it attaches to the seat bottom, and now it flips forward just fine.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 09-09-2008, 10:40 AM   #7
Husker
Husker's Avatar
I parted a 70 Chevy and it had a flip seat, and I have a 68 Chevy and a 70 GMC and they both have fixed seats.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 09-09-2008, 10:50 AM   #8
michael bustamante
michael bustamante's Avatar
My67 custom cab had the flip seat but I junked it. was that a mistake? are they rarer to find?
As a replacement I used a bench seat from a 94 silverado. (flip seat back)
1967custom
michael bustamante is offline   Reply With Quote
Old 09-09-2008, 01:57 PM   #9
jorgensensc
jorgensensc's Avatar
O also removed the upper bolt from the '72 I had. I used a nice fabric grommet through the seat material and then used a pull pin (long straight with a little ball at the end, and a key ring pull on the other end) in the upper bolt hole. When I wanted to lean the seat forward, I just reached down, pulled the pin, and leaned the back forward. Worked like a champ. I only used the pin on the driverside, I rarely have passengers.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
