11-17-2002, 06:50 PM | #1 |
someday
Blazer Question again
I was wondering if the frames were different from a 4x4 and 2x4 or from leaf and coils i found a 2wd but its leaf springs and i wanted to comvert to coils to bag it and i know there weredifferences in frames just cant remember what it was
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
11-17-2002, 07:04 PM | #2 |
if it's a factory 2wd frame with leaves it should be the same as a coil just without all the right crossmembers witch you could get from any 2wd truck and drill the holes and bolt in. I think I have all the crossmembers you need let me Know if you need them
67 chevy short step 2wd 427 71 chevy short fleet 4x4 396 72 gmc jimmy 2wd 377 71 chevy blazer 4x4 454 69 chevy longhorn 5.9l cummins 72 chevy 400 2wd custom camper 67 chevy lwb 4x4 454-in pieces 67 chevy panel soon 4x4-400 67 gmc dump 4x4 1 ton-305 WTF!! 72 chevy 3/4 ton 4x4 burb 350 70 chevy panel 2wd 302 5 speed tko "THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!! |
11-18-2002, 12:40 PM | #3 |
Does that leaf spring 2WD Blazer have a 4WD vin?
Tim |
11-18-2002, 12:47 PM | #4 |
someday
i dont know i was gonna ask that very question though
11-18-2002, 01:00 PM | #5 |
Almost Satisfied
I have a question on this topic. I have found a 4x4 Blazer here, but want to make it a 4x2. Can I just lift the body off and bolt it to a coil spring short bed truck frame? If not, then I am wondering how to get rid of the leaf set up and go to the coil set up as well. Can one recoup any money from the driveline of the 4x4?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-18-2002, 01:59 PM | #6 |
A Blazer frame and a swb frame are not the same. But as far as I know, of you had a 2 wd coil frame donor, you can take the 2wd suspension and bolt it to the Blazer frame. To make it a coil sprung 2x4.
