Old 09-09-2008, 12:19 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Airbaggers. Where are you putting your tanks?
I have a 71 swb stepside with the fuel tank in the rear. Where are you airbaggers putting your airtank. I dont want to put it in the back of the bed, i want it underneath somewhere...
Im thinking of putting it inbetween the cab mounts on the outside of the frame.. Would that fit?? There is 35 inches between the cab mounts. the diameter of the tank is about 10 inches.... Anyone done this before???
basically putting it here, on the outside of the frame rail.. I dont have the cab on so i cant really get an accurate measurement...
I was also thinking of using 2 5gallon tanks but the suicidedoor guy said that it would be best to run 1 8 gallon tank.... Thats a tough spot to find some room for..
lyrikz is offline   Reply With Quote
Old 09-09-2008, 12:49 PM   #2
umwtnt
umwtnt's Avatar
Re: Airbaggers. Where are you putting your tanks?
Hey lyrikc, I can't answer your question yet because I have not gotten my air tank. But, I would like to thank you for the picture because I have been trying to figure out where to install my mufflers and I believe you have given me my answer. I am running the big 70 series flowmasters, Initially measurement indicate I may be able to install them like you have. If I had the measurements of a five gallon tank I could measure under neath my cab, on the outside of the frame rails, and see if the tank would fit. My cab is currently set in place.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 09-09-2008, 01:22 PM   #3
lyrikz
PITbut
lyrikz's Avatar
The tanks dimensions are
Specs:
Length - 32"
Diameter - 9.5"
Height with legs - 11.5"
Let me know sir... Let me know the measurements of your muffler i might be able to take a measurement for you.
Old 09-09-2008, 01:43 PM   #4
jorgensensc
jorgensensc's Avatar
HA! Don't you remember me asking the same thing? I never did find a good place to mount my 1 gallon tank. I can't imagine mounting something bigger than that. It wouldn't fit anywhere along the frame rails without hanging lower where you would see it. The only spot I could find was behind the rear wheels in the fender area mounted to the frame. But them you have a big tank that you can see in the wheel wells. Good luck to you. I am just going to end up doing a static drop in the rear. I will be putting the air bags on the burb, along with the hidden reciever. I will just use that to tow with. After all, it does have the big block! For now! HAhA
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-09-2008, 02:05 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Shawn
crap.. i dont want you to be able to see the tank. guess i can just run it in the bed... iddnt want to though.
Old 09-09-2008, 02:51 PM   #6
c10addict
c10addict's Avatar
I mounted my 2 3 gallon tanks between the two rear most crossmembers..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 09-09-2008, 02:55 PM   #7
lyrikz
PITbut
lyrikz's Avatar
You have your gastank in the stock location? I have my gas tank back there.. Im sure i will find a place somewhere...
Old 09-09-2008, 03:03 PM   #8
c10addict
c10addict's Avatar
Yep I sure do... Sorry...
Old 09-09-2008, 03:41 PM   #9
kevncar
Active Member
kevncar's Avatar
is this a stepside issue? I hadn't really taken any measurements yet but had planned on running a 5 gallon tank on the outside of the framerails under the bed just in front of the rear wheels on my SWB.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 09-09-2008, 03:42 PM   #10
lyrikz
PITbut
lyrikz's Avatar
Ya... absolutely....
I found a thin 5 gallon tank... I have a mock up of its so im going to see how well it sits on the frame.... Im hoping it works out ok.. that would be nice have 2 5 gallon tanks on the outside fram rails...
Old 09-09-2008, 04:13 PM   #11
lowriden58
lowriden58's Avatar
another thing to consider is air compressors, how many? what size? if you go with a big tank(s) and only have 1 or 2 small compressors it will kill the performance and the life of the compressors.
just and FYI i had 4 viair 480s with a 12gallon.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 09-09-2008, 04:19 PM   #12
lyrikz
PITbut
lyrikz's Avatar
i planned on running two viar 400s or 420s whatever the number is, and two 5 gallon tanks. Im going to connect the two tanks.. BUTTT before i do anything im just running the rears first, then adding the fronts later....
So basically a 420ish compressor and a 5 gallon tank.... Then later down the road another 420ish compressor and another 5 gallon tank... Whats your thoughts on that????
Old 09-09-2008, 04:32 PM   #13
lowriden58
lowriden58's Avatar
i honestly would get the Dual 480 pack from SSD. you will save $$ in the long run. the 400 & 450 are not as efficent as the 480. i believe they also have a 1/4" leader hose vs the 3/8" leader hose on the 480. 480 is a 200psi rated comp, 400/450 are rated 150psi. also IMO the good rule of thumb for comp/tank ratio is 3gal per comp.
Old 09-09-2008, 05:22 PM   #14
fastom
That's right, it's Copper!!
fastom's Avatar
Would a 3 gallon tank and one compressor work on a front/rear system? I was going to run that way but after reading this post I'm confused.
I'm not looking for a fast system.
fastom is offline   Reply With Quote
Old 09-09-2008, 05:29 PM   #15
lyrikz
PITbut
lyrikz's Avatar
Same here, im not looking to up and down.. Basically down at the show, and up when im done... I wont be doing alot of up and downing in a row... Get me????
My setup would work fine for that right?? 2 seems like overkill. I just want to be able to go down front and rear and up front in rear without having to wait... Just once.... Well, once within 3 or 4 minutes ya know...
Old 09-09-2008, 06:10 PM   #16
Riveted1
Tasty Cakes!
Riveted1's Avatar
I got a 5 gal. "slim" tank and it looks like it will fit outside the PS frame under the cab. I've just mocked it up a few times when I was running through stuff in my head. If not, I'm gonna have to find some stubby ones for outside of the frame behind my wheels. Mine's a fleetside though. If that doesn't happen, the slim tank will be goin in the front of my bed.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 09-09-2008, 06:25 PM   #17
Painter D
Painter D's Avatar
Here's my 5 gal. tank. You can't see it when the bed is on.
Ignore the wiring, it's temporary.
Painter D is offline   Reply With Quote
Old 09-09-2008, 06:26 PM   #18
lyrikz
PITbut
lyrikz's Avatar
I got no pic you teaser.
Old 09-09-2008, 06:27 PM   #19
Painter D
Painter D's Avatar
It didn't work , give me a few minutes.
Old 09-09-2008, 06:38 PM   #20
Painter D
Painter D's Avatar
Well I can't get my pic to post. Either way it's a 5 gal. tank mounted on the pass. side, outside frame rail, in front of the back wheel. You can't see it when the bed is on the truck. Hope this helps.
Old 09-09-2008, 07:17 PM   #21
lyrikz
PITbut
lyrikz's Avatar
Oh man, can you link it or something? Your killing me here. ahaha...
Old 09-09-2008, 07:40 PM   #22
lowriden58
lowriden58's Avatar
i get ya, but what im trying to say is basically a 3gallon tank wont do it for ya. raise the front or rear 1 time by itself and your out of air.... thats all im saying so choose the right comp/tank setup wisely. too much tank and not enough compressor and you will kill that comp, it will run longer and drain your battery faster than a multiple comp setup.
Old 09-09-2008, 07:51 PM   #23
lyrikz
PITbut
lyrikz's Avatar
Im running 10 gallons and two compressors... 5 gallons and 1 comp should be fine for the rear right????
Old 09-09-2008, 07:54 PM   #24
lowriden58
lowriden58's Avatar
yeah should be fine, which comp you gonna run? i havent checked out the 420 yet to see what the cfm rate is
Old 09-09-2008, 08:09 PM   #25
lyrikz
PITbut
lyrikz's Avatar
Let me get that info. for ya.
Here is the info on teh comp.. Its a 450 viair. tell me what this mumbo jumbo means and if in the future, two 450's and 10 gallons is good for what i want.. IT HAS to be good. ahaah.. id ont want to bounce with it.
Description:
STANDARD FEATURES:
-Oil-Less design
-Hi performance PTFE piston ring
-Stainless steel valves
-Moisture & dust resistant
-Gear-less direct drive motor
-Anodized aluminum alloy cylinder
-Automatic reset thermal overload protector
-Mounting plates with vibration isolators
-Stainless steel braided leader hose
-Remote mountable intake filter assembly
-Inline check valve
450 Specification:
-Voltage: 12 Volt & 24 Volt
-Max. Amp: 23 AMPS
-Max. Working Pressure: 150 PSI
-Max. Ambient Temp: 158 F
-Min. Ambient Temp: -40 F
-Motor: Permanent Magnetic
-Max. Duty cycle @ 100 PSI: 100%
-Dimension: 12.75" L X 4.00" W X 7.00" H
-Net weight: 9.75 lbs
"VIAIR warranties only compressors that have been installed using their
installation instructions included with each compressor. Installation of an
adjustable pressure switch can allow compressors to operate beyond their
rated duty cycle and working pressure. Use of an adjustable pressure switch
will void the warranty on any VIAIR compressor."
