Old 09-09-2008, 04:48 PM   #1
Jerblazer72
Wiring diagram for engine compartment with factory AC NEEDED!
everyone,
I have a 72 gmc truck and 72 blazer cst. Both with factory air set up. I am putting the engine back into the truck and want to eventually get the ac running. Problem is that the wiring was not hooked up to the AC on either vehicle and I dont know what goes where. If I remember right there was a solonoid on the carb that kicked it up a bit when the ac was on, but I can find no info on this or any other items for the ac wiring. If I do a forum search it dumps the words air, conditioning, and ac as being too common or long. Can someone/anyone please point me in the right direction?
I have looked at the color wiring diagram in the sticky section under electrical but there is no ac shown. Thanks in advance for any help.
Jerblazer72 is offline   Reply With Quote
Old 09-09-2008, 07:20 PM   #2
JimKshortstep4x4
Re: Wiring diagram for engine compartment with factory AC
Here is an AC wiring diagram. It does not have the carb solenoid wiring that you are asking about. I have only seen trucks with a solenoid as part of the TCS setup and I don't have any wiring information on what you are asking for on it. Maybe someone else has the info on the solenoid like you are thinking of.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-09-2008, 08:43 PM   #3
haysonj
haysonj's Avatar
Not sure where I saw it maybe LMC but any auto parts place will sell the solinoid but no bracket. The solinoid hooks to the wire on the compressor so it will operate when compressor is on
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
