Old 05-10-2002, 12:42 PM   #1
CodyNTCC
Question Coil Springs question?????
Ya'll told me that i can only go with 2 inch drop coils or it will be messed up. Is this 2 in.coils all the way around or 2 in. in the front and something like a 4 in. in the back to level it out. Thanks for any info you can give.
Black '69 LWB
Black '69 LWB
CodyNTCC is offline   Reply With Quote
Old 05-10-2002, 12:47 PM   #2
paintpyro
paintpyro's Avatar
Post
2 inch in the front, you dont have to worry about the geometry in the back, can run all the way up to a six inch drop spring, anything over 4, you may need to notch the frame, and get an adjustable panhard bar and shock relocators
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 05-10-2002, 12:59 PM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Post
Cody, my 2 cents:
Buy the drop spindles! My truck was origninally lowered using just springs and the camber on the truck was terrrible. They never could get the truck close. It had more schims in it than little pigs house made of sticks!! You have to convert to disc brakes, but other than more cost it is well worth it.
As for the back. You can simply block the rearend. Have some steel blocks cut at the desired width and get some longer u-bolts. It is an easy and inexpensive way to lower the rearend with no loss of performance. Again, shortened springs would be best.
Good luck
2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it
1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-10-2002, 01:30 PM   #4
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
2-4 WILL BE LEVEL, Almost all chevy trucks come from the factory with a 2" rake.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
