Old 09-10-2008, 12:00 AM   #1
danman987123
danman987123's Avatar
cab seal question
Is there a weatherstripping that goes around the door frame and seals when it hits the cab as well as one that is on the cab. I know of the one that goes along door frame but what about the little lip on the cab? if you notice on this truck built by fesler http://www.feslerbuilt.com/1968Chevytruckpur.htm it has rubber on the cab lip....and none on the door.......but if you go to brotherstrucks, ecklers, or earlyclassic, they all sell you door to cab seals which mount on door? HOW DOES THAT MAKE SENSE.....I CAN GO ORDER FROM THEM AND LOCALLY I CAN BUY THE RUBBER FOR THE LIP AROUND THE CAB....BUT WHICH IS THE PROPER WAY??
danman987123 is offline   Reply With Quote
Old 09-10-2008, 12:07 AM   #2
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: cab seal question
No weatherstripping hooks to the door. This one is easy, go to your local junk yard and get a set of door seals from a '96ish full size Chevy truck. They also, like ours, have the pinch welt on the cab, not the door. Unlike the 67-72 seals which have to be glued on, these have a pinch seal and work perfectly. They look great. They are a shade too long so they need to be cut to length. Cost me like 10 bucks for both seals.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 09-10-2008, 12:23 AM   #3
danman987123
looks great ok. thanks. just confused because this says that it goes onto door..... http://www.brotherstrucks.com/prodin...number=DFS6772 thanks appreciate the info though....now i know what to get.
Old 09-10-2008, 12:27 AM   #4
matthufham
it doesn't say it mounts on the door, it doesn't say anything about how it mounts, it's just saying the job of the weatherstripping, to seal between the door and cab, to keep water out. it could be more specific
matthufham is offline   Reply With Quote
Old 09-10-2008, 12:28 AM   #5
Richard8971
LOL, well I would be concerned that they are showing a pic of a cab that is def NOT a 67-72 Chevy truck. Like i said, save time and money, hit the junk yard.
Don
Sherlock Holmes
Old 09-10-2008, 02:07 AM   #6
mr48chev
mr48chev's Avatar
The seal in that photo is correct and the truck is a 67/72. You made me go out and look at my 71 to be sure. That seal looks a lot better than mine though.
Old 09-10-2008, 09:11 AM   #7
nightmare
nightmare's Avatar
Don
Don, do you have any problems with the seals staying on the cab? Did you use any glue at all? I bought the seals to redo mine, but haven't yet because I dread doing the waiting process of letting everything dry. That looks good on there.
Mike
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 09-10-2008, 10:56 AM   #8
matthufham
he meant when you go to brothers website listed above, the cab in their diagram is a 60-66 i think not a 67-72
Old 09-10-2008, 12:40 PM   #9
68gmsee
Active Member
68gmsee's Avatar
I couldn't find any decent push type at the junkyard so I bought them from GMCPauls -local vendor.
68gmsee is offline   Reply With Quote
Old 09-10-2008, 12:43 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Here's the site...
Scroll down
http://www.gmcpauls.com/Pickup.htm
Old 09-10-2008, 02:11 PM   #11
danman987123
ya that orange truck does look good....can you send me pictures of the seal by the step plate......thanks
Old 09-17-2008, 04:25 PM   #12
danman987123
can some one show me a picture with this 90's weatherstripping and the door sill.....i wanna see how the plate covers the weatherstripping or how it fits....thanks
