longhorn
anybody know what axle and gear ratio is in the longhorn pickup? looks like a dana 60 from a glance.
newly minted old timer
Re: longhorn
![]() there is mine, not sure what gears are in it, but at 70 mph im running 3100 or so rpm... 373?
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
its all about the +6 inches
Re: longhorn
Dave, yours should be a 4.10.
hou72che, we need to know what engine and tranny it came with originally, and if the rear looks like the one above. |
Re: longhorn
big block longhorn. does not have that rearend. isnt that a corperate? pretty sure its an automatic? just glanced under it really quik. have had the truck for years but never touched it
Re: longhorn
if it is a 3/4 ton, then it should be a dana (you are right about the photo, that's the Eaton HO52, or corperate rear) and the gearing should be a 3.54 id a big block and automatic.
If it's a one ton, then 4.10, but I don't think the dana was offered in the one tons. |
#6 | |
I'm a poor spectator
Re: longhorn
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Re: longhorn
the orig. engine was the 350...usually see the 3.54 geared dana 60's behind big blocks.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Re: longhorn
3.54 was pretty much a big block only gear. you could get the dana, but the Eaton is the base model, or standard rear end.
Re: longhorn
thanks guys im gathering that it is the dana 60 with 3.54 gears.
