Old 09-10-2008, 10:32 PM   #1
Michael Hill
Fuel tank selector valve leaking!!!!!
I have an 86 GMC short bed two wheel drive truck with dual fuel tanks. My problem is the selector valve that allow you to switch from one tank to another has a crack in it and its spilling gas everywhere. I went to Napa Autoparts and at a Chevy dealer with no luck, also loooked on LMC, and Brothers with no luck. Does anyone know where i can get another one? Any help would be greatly appreciate, thanks Michael from Arizona.
Michael Hill is offline   Reply With Quote
Old 09-10-2008, 10:40 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Fuel tank selector valve leaking!!!!!
I have bought them at Autozone, NAPA, GM and Advanced Auto.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-10-2008, 10:42 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
advanced auto has themonline heres for an 82 but they have em all
http://www.partsamerica.com/ProductL...pe=831&PTSet=A
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-10-2008, 10:51 PM   #4
orbot
orbot's Avatar
Bought mine at the local dealer dont know if it was cheap or not but in that moment i thought i needed it, but no i did not it was only the fuel filter..
orbot is offline   Reply With Quote
Old 09-10-2008, 11:31 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Find an A/C Delco store.
gchemist is offline   Reply With Quote
Old 09-11-2008, 02:01 AM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I found the listing for the selector valve on NAPA's websight. Had to do some digging but I finally found it.
Fuel Tank Selector Valve
Part: CRB 22198
Product Line: Echlin Fuel System
Price : 124.00
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-11-2008, 11:40 PM   #7
raiders3581
Junior Member
raiders3581's Avatar
Thats the same one i used on my 87 bolts right on
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi
raiders3581 is offline   Reply With Quote
Old 09-12-2008, 12:08 PM   #8
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
The GM and AC Delco part number is 14029228. I just bought one a few months ago for some where around $100 if I recall. It is the same Pollak valve that you find at Napa or anywhere else. Someone has to have one at a decent price. A GM stealer will probably put the screws to you for it though.
DirtyLarry is offline   Reply With Quote
Old 09-12-2008, 02:13 PM   #9
bendele
Does anyone know the pressure rating on these fuel tank selectors? I'm planning to put a TPI setup in my truck at some point. I'd like to run my pumps in the tanks but that would require the fuel tank selector to handle the pressure.
bendele is offline   Reply With Quote
Old 09-12-2008, 02:40 PM   #10
DirtyLarry
DirtyLarry's Avatar
Yes, it is 65 PSI max pressure for that valve. You can find the spec sheet on that valve on Pollaks website.
Funny you should ask that question as I just put a 8.1L in my truck and had to bypass the valve as the return line that runs through the valve back to the tank is too restrictive and caused the fuel pressure to run around 100 PSI, which is way too high. I decided to run a Corvette in-tank pump on the RH side as well as an aftermarket center mounted high volume low pressure pump to transfer fuel from the LH to the RH tank and do away with this valve all together.
The Pollak switch valve discussed above was not designed for high fuel pressure systems. TBI only ran around 12 PSI with the return pressure no more than a dribble. The MPI on my Marine controlled 8.1L and your TPI require around 38 to 43 PSI with a clean restrictive free return line back to the tank. I am sure you will find this valve too restrictive on the return side as well which will cause fuel pressure issues at the engine.
Old 08-15-2017, 10:17 AM   #11
Magicnbomber90
It's a little off the topic but I have a 1976 k10 with dual fuel tanks and my question is, is the 5/16th size hose for the vapors? Because I have a 3/8ths and 1/4 as well but I don't know which one between the 1/4 and the 5/16th is the return from the carb
Magicnbomber90 is offline   Reply With Quote
Old 08-15-2017, 05:39 PM   #12
Prong
The 5/16" line is for vapor and the 1/4" is for fuel return.
Prong is offline   Reply With Quote
Old 08-15-2017, 06:00 PM   #13
Magicnbomber90
That explains the fuel leak coming from there
Old 08-15-2017, 09:14 PM   #14
kwmech
It's the other way around
Old 08-15-2017, 09:33 PM   #15
donw1986
Just bought one last week at a napa in so cal 92.00
donw1986 is offline   Reply With Quote
