Old 09-11-2008, 12:15 AM   #1
jorgensensc
jorgensensc's Avatar
What clips are y'all using?
THe last peice of trim that needs to go on the burb is the piece that goes across the back hatch at the handle level. I asked at the swap meet this weekend and was told that they don't reproduce these clips and I would need to modify some. Is this true? If so, What clips are y'all using for it?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-11-2008, 06:09 AM   #2
Rokcrln
Rokcrln's Avatar
Re: What clips are y'all using?
Call and talk to Stan at ECE (888) 777-0395 and tell him Kevin from LFD sent you. He should be able get you in the right direction even if he does not have the part.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-14-2008, 11:39 PM   #3
jorgensensc
Ttt
Old 12-15-2008, 09:54 AM   #4
suville
suville's Avatar
Over the years I've had good results with these folks: http://www.restorationspecialties.com/products.htm Hope this helps, sorta like findin the "correct" 67-68 chicken lip mldg clips some are difficult to locate!
suville is offline   Reply With Quote
Old 12-19-2008, 09:25 PM   #5
1sik7t2
dave
1sik7t2's Avatar
i'm in need of the same clips looked everywhere i cant find them either please let me know where thx
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
