Old 09-11-2008, 10:03 AM   #1
gottwake
gottwake's Avatar
Anyone running parrallel 4 link?
I want to install parrallel 4 link. Any pros or cons to this setup that I should know? Anyone have pics?
Blazer Project
gottwake is offline   Reply With Quote
Old 09-11-2008, 04:17 PM   #2
leftcoast66
leftcoast66's Avatar
Re: Anyone running parrallel 4 link?
There's a lot of opinions on what is best, and it just depends on your application and likes. Its great because the pinion angle doesn't change as it moves up and down, but that can create negatives if you are on air and like to drive it at multiple heights. All just a matter of what your doing with it and what your willing to accept and be ok with.
leftcoast66 is offline   Reply With Quote
Old 09-11-2008, 04:30 PM   #3
gottwake
gottwake's Avatar
I see...Can you be more specific? I will be on air and plant to only have two heights. A few inches off the ground and lying on the frame. I’m just not sure if the position matters. You know, the connection to the frame, adjustment of the bars (length), or anything else. I like it because it seems easier to install than triangulated 4 link. I have other options, like two bars and a wishbone. So I am open to the idea of other types of 4 link, but like i said, this seems easier. Not everything is as it seems though.
Blazer Project
Old 09-11-2008, 10:21 PM   #4
FnLow69
FnLow69's Avatar
easier maybe but you need a panhard bar with a parallel 4 link. same with most 4-link you need to stay within the set ride height for the best pinion angle...as well as longer bars generally ride better.
FnLow69 is offline   Reply With Quote
Old 09-11-2008, 11:26 PM   #5
gottwake
gottwake's Avatar
I was going to use a wishbone rather than a panhard (is that okay?). Also, I suppose that I will always have it at ride height except for car shows etc...Correct?
Blazer Project
Old 09-11-2008, 11:51 PM   #6
FnLow69
FnLow69's Avatar
you mean like a three link (upper links connected)...if so its not needed. if you wanna run a wishbone than use one lower link (per side) and i would mount the bags on the lower link for more lift and a better ride... but a panhard is was easier to setup than a wishbone.
Old 09-12-2008, 01:51 AM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
a properly set up panhard bar will give you NO troubles. I'm running a parallel four link with a nice long panhard bar and it's fine. I have sleeve bags over the axle and it rides like a Cadillac.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-12-2008, 10:52 AM   #8
gottwake
gottwake's Avatar
Smashing chuck, you have pictures of your setup?
Blazer Project
Old 09-14-2008, 09:45 PM   #9
smashingchuck
just snapped these tonight....
78 Build Thread
4Runner Build
Old 09-14-2008, 09:56 PM   #10
ca180
tryin to get laid
Holy big pictures Batman!
Great stuff man, looks good.
You runnin boggers on that thing?
ca180 is offline   Reply With Quote
Old 09-14-2008, 10:23 PM   #11
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Here's the wishbone I built for the rear of my '62. This would work great for a parallel four link. The middle link to the rear end is telescopic so the axle tracks straight and the suspension can run in it's arc without trying to rip apart the locator and will not travel in a side-to-side arc during suspension travel. Also, if you run the upper bars at a more downward angle to the lower bars accordingly, and depending on the length of all the bars. the pinion angle will stay in perfect relation to the driveshaft.
Imperial Kustom is offline   Reply With Quote
Old 09-14-2008, 11:41 PM   #12
smashingchuck
no...
78 Build Thread
4Runner Build
Old 09-14-2008, 11:51 PM   #13
gottwake
gottwake's Avatar
Im gonna have to get me a build thread. Thanks smashingchuck for the pics. Is that a suicidedoor set up?
Blazer Project
Old 09-15-2008, 12:11 AM   #14
ca180
tryin to get laid
Originally Posted by smashingchuck View Post
no...
It was a joke bro, I've kept up with your whole build
Old 09-15-2008, 12:36 AM   #15
67Cowboy
"GOD BLESS AMERICA !!!"
67Cowboy's Avatar
Thumbs up Re: Anyone running parrallel 4 link?
My $0.02 : most serious Drag Racers use the 4 Link because of the adjustment will allow you to make it track the way you want it to. Also you can use what is called a watts link in place of the panhard bar. There was a build thread here at one time that had links to a website with a working watts link and 4 link set up.
_ I have a '67 Chevy with trailing arms and I'm thinking of building a watts link to work with my setup. Heres's the place I found for parts: http://www.jegs.com/webapp/wcs/store...FQv7agodMX9AXw
http://www.fays2.net/fays2_watts_link_23_.html
_ Also I found some stuff at Circle Track Supply that I may end up using.
67Cowboy is offline   Reply With Quote
Old 09-15-2008, 12:37 AM   #16
smashingchuck
ART universal. I really like it.
78 Build Thread
4Runner Build
Old 09-15-2008, 01:20 AM   #17
gottwake
gottwake's Avatar
Hey chuck.. you have the web site for that place? Also, its my understanding that the bars should be parallel with the frame at ride height. Are yours?
Blazer Project
Old 09-15-2008, 09:49 AM   #18
smashingchuck
I think this is the kit that I have, only mine has a longer panhard bar. I also fabbed my own upper and lower mounts, and am no longer running the shocks it came with.
http://www.ridetech.com/products/Par...s-1466-78.html
The mounts for my four link are actually a little high, but they are pretty close to parallel. When I put mine together is was all a guess... wish I knew now what I didn't know then, but it all seems to work just fine.
78 Build Thread
4Runner Build
Old 09-15-2008, 11:18 AM   #19
gottwake
gottwake's Avatar
Hey thanks, your truck is the nicest one of that model that I have ever seen. Nice job. Thanks for the info.
Blazer Project
