Old 11-17-2002, 11:18 PM   #1
Tim Christian
Tim Christian's Avatar
Question Blazer Question?
Is a factory 2-wheel drive Blazer Coil or Leaf spring? How do you tell if it is a factory 2-wheel drive? Thanks
Tim Christian is offline   Reply With Quote
Old 11-17-2002, 11:27 PM   #2
Alexis
Member since 2000
Alexis's Avatar
they came with coil and leaf. to know it is an original 2wd you got to get the Vin number and make sure it matchs up with the frame vin number.
Alexis is offline   Reply With Quote
Old 11-17-2002, 11:33 PM   #3
6772king
6772king's Avatar
you can also tell buy the frame a 2wd bow's out right over the rear axle as a 4x4 is strait (narrower)
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 11-17-2002, 11:36 PM   #4
Alexis
Member since 2000
Alexis's Avatar
totally forgot about that.......whats wrong with me.
Old 11-17-2002, 11:38 PM   #5
Tim Christian
What part of the vin # tells you?
Old 11-17-2002, 11:43 PM   #6
Alexis
Member since 2000
Alexis's Avatar
first it's just like a 2wd truck "C" and the last digits of the vin numer should be the same as the ones stamped on the frame above the steering boxs.
Whats jumping around your mind Tim?
Old 11-17-2002, 11:44 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The first digit on 69 - 71 will be a C for 2 wheel drive, or a K for 4 wheel drive.
On a '72, the first will always be C on a Chevyrolet, but just look at the second one...again, C or K.
Old 11-17-2002, 11:49 PM   #8
Tim Christian
Smile
Thanks Guys. I am by no means a Blazer expert. LOL
Old 11-17-2002, 11:57 PM   #9
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Are you sure about the leaf option on 2wd? I've always heard that 2wd Jimmy/Blazer are coil only. Also, I've never seen a leaf 2wd Jimmy/Blazer. I believe that is only true for the trucks. I'd like to see some documentation.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 11-18-2002, 12:37 PM   #10
Blazer1970
Blazer1970's Avatar
I agree with 70 Jimmy. I think we have verified in the past that all 2WD Blazers/Jimmys of this era had coil spring rears. The brochures from these years also show this to be true. No leaf spring option on 2WD Blazer/Jimmy. If you find a 2WD with leafs in the back, it has been converted from 4WD, and there are a bunch of these conversions floating around out there.
Blazer1970 is offline   Reply With Quote
Old 11-18-2002, 08:40 PM   #11
6772king
6772king's Avatar
haven't seen very many 2wd factory blazers but every one was coil
Old 11-18-2002, 09:28 PM   #12
70 Jimmy
70 Jimmy's Avatar
The converted ones are still desireable. Just don't let anyone try and fool you. I'm thinking of putting "X 4X4" on my plates. LOL
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 11-18-2002, 10:43 PM   #13
Dan69 step
2wd are all coil. I know there aren't that many true 2wd's out there, but still coil.
69 short step
68 50th Anniversary Gold/ White lwb
72 2wd Blazer
63 Studebaker Avanti
85 Avanti
66 Studebaker Cruiser
49 Studebaker pickup
3-49 Studebaker 1 1/2 truck
94 White/ GMC coe (cabin hauler)
95 chev
2015 chev Duramax 2500
Dan69 step is offline   Reply With Quote
