Old 09-11-2008, 02:50 PM   #1
67mater
67mater's Avatar
converting to 4L80 auto and column shift
I am going from a 4 speed manual to a 4L80E and NP231. Anybody know what it takes to go to column shift? I'm seeing used auto columns go for $50 and then how do I do the linkage? Should I just get a Lokar floor shifter? I see the 32" one; anybody got this?
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 09-11-2008, 03:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: converting to 4L80 auto and column shift
have you looked into the computer that it'll take to run that tranny? Moe acuratly... the cost involved?
Old 09-11-2008, 03:33 PM   #3
67mater
67mater's Avatar
computer and harness coming from donor. is there more I should be worried about?
1967 K10
1967 Camaro
Old 09-11-2008, 04:22 PM   #4
airdale94
airdale94's Avatar
You might be able to get the colum and linkages to work from the donor vehicle. If it is the 88-94 variety. You would have the ignition on the colum though. I guess you wouldn't have to use it.
airdale94 is offline   Reply With Quote
Old 09-11-2008, 04:25 PM   #5
67mater
67mater's Avatar
column not availble. I was lookign into a 68-72 auto column, or perhaps a Loakr floor shifter (buy they are pricy)
1967 K10
1967 Camaro
Old 09-11-2008, 11:03 PM   #6
runpasthefence
runpasthefence's Avatar
I'm curious as well. I'm planning a LQ9 - 4L80 conversion, but I'd like to to keep my column shift. What has the solution been for the 4l60? Is everyone going floor shift?
runpasthefence is offline   Reply With Quote
Old 09-11-2008, 11:59 PM   #7
trx450duner
trx450duner's Avatar
I did this conversion in my 70' and I got a mid to late 70's van coloumn and put a mid 80's van detent and indicator assembly in it. This allowed me to maintain a non keyed, tilt, coloumn shift set up that even had the detent and indicator for an overdrive. It bolts into the truck just like your original and GM sells the adapter pig tail to hook your trucks wiring to the later model coloumn (direct plug in no splicing). As far as the linkage I used a lokar set up, they sell a universal shift linkage that bolts to the coloumn and trans and you just cut the rod to leangth. If interested in this conversion and you need the pigtail harness I can dig up the GM part # so you can take that to the dealer.
trx450duner is offline   Reply With Quote
Old 09-12-2008, 07:45 AM   #8
Great info!This should be in FAQs.
Old 09-12-2008, 08:09 AM   #9
runpasthefence
Agreed, here's the page on the Lokar website.
http://lokar.com/interior_pages/colshiftlink.htm
Old 09-12-2008, 09:27 PM   #10
trx450duner
One more thing to anyone that may do this conversion, you cant just put the detent and indicator from the van into your 67-72 coloumn it doesnt fit. 73 is the year they changed the coloumns in the trucks so I would think that anything from 73 up for the van would fit the later detent ass. and the sweet part is if you score this in the wrecking yard you can swap it all over there and just buy a coloumn and not the extra parts too.
Old 09-13-2008, 08:21 AM   #11
Gray Ghost
Gray Ghost's Avatar
I don't have pics but my buddy Bill has the 32" shifter in his panel truck. The Lokar kit has a very strong bracket setup and bolts in with ease.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
