Squarebody Aficionado
can't pump gas
This might not sound like a bad thing but i can't put gas in my truck, whenever i go to put gas in my truck it kind of spits it back out like a juice box that you blow air into that just leaks everything back out at you. Im not sure what it could be. my switch is on the RH tank and it lets me put gas in that one but im not sure if that would have anything to do with it, this has never happened before and i need to put gas in my truck because my gas guage isnt working. if you guys have a way for me to check my guages let me know the only one that is working is my speedo and its off because of my 3.73s.
Re: can't pump gas
I have the same issue. Both my fill and vent lines are rotted bretty badly. I was going to replace them and see if that helped.
Seems to me that if the vent line is rotted/collapsed/otherwise blocked that it would be the most likely culprit. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: can't pump gas
You are probably putting the nozzle to deep in the filler... If it is aimed toward the curved portion it will do that too..
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: can't pump gas
it might be the filler neck got flattened by some debry flinging onto it from the tire .
you might check inside the rearfender if you can see the fillerneck , you could allso try to get the side you fill the truck over a bit higher by parking it halfway on a curb or sumtin
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#5 | |
Re: can't pump gas
BAD BOW-Silverado XST
Re: can't pump gas
I had a similiar problem. The tank was FULL!! The switch would not switch tanks.
