Old 09-11-2008, 09:06 PM   #1
lofly'a
lofly'a's Avatar
Question show me your drop w/o bed modifications?
i need an idea on how much (drop & driveability) i can get without cutting the bed. i am also taking into account driveability at that height. my plan is to get as low as possible with bags at all 4 corners, which will include relocating the rear bag mounts and a watts-link that i already have built to maintain center, but am still deciding how i will mount it behind the chunk. i have a 6.0 gen 3 engine/trans and 4th gen camaro headers & exhaust that'll pass through the trailing arm crossmember. i need pics & stats please, i don't want to drag anything, but i would like to have the ability of putting it on the stops when parking at shows , but this will be a driver and a father/son project. i know that i 'll be fabbing my own notch, because i don't like the way the others (bolt ins) fit. i will alter the fenderwells if necessary (taller/wider), but i don't care for the look of the raised section at the rear of the bed or the middle hump in a "partial" section. again, i need pics & stats.............thanks.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 09-11-2008, 10:02 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: show me your drop w/o bed modifications?
Here is my truck at dump with no notch & no drop spindles
And my old truck same thing
With any notch you are gonna have to cut a hole in you bed floor for the top of the rear axle to poke through
If you want to have a smooth floor, then just do a floor raise on your bed & put as big a notch as you want
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-11-2008, 10:56 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
This is as low as you can get with a stock bed and fender liners. It did take some mods in the rear wheel wells though, but nothing visible.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-11-2008, 11:14 PM   #4
lofly'a
lofly'a's Avatar
thanks Spray-bomb, but i ain't cutting. don't like the look and theres no such thing as a flat smooth street in Louisiana so......... N2TRUX, that is the look/stance i'm wanting, what are the stats on your truck. and please keep the pics coming guys
Old 09-12-2008, 12:32 AM   #5
Ackattack
Ackattack's Avatar
Here's mine: it has a c-notch but the bed floor is stock (as far as for axle clearance...tubbing it for more tire room though)
the C-notch is homemade. I'm also using camaro headers and will tuck the exhaust up through the crossmember. My build thread has a lot more info and pictures.
Ackattack is offline   Reply With Quote
Old 09-12-2008, 05:05 AM   #6
lofly'a
lofly'a's Avatar
thanks Ackattack, i read your build up to date & you have answered a few questions and gave me a few good ideas. i will be using the gen 4 camaro tank also, i like the fit. i plan on bringing the fill tube up thru a stack pocket hole with a little modification and a marine type filler cap like i've seen done by a member of the board here before.
please guys, keep the pics coming.
Old 09-12-2008, 06:10 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by lofly'a View Post
.......... N2TRUX, that is the look/stance i'm wanting, what are the stats on your truck.....
lofly'a that truck once belonged to forum member n2billet. Here's his build thread-LINK
Unfortunately many of the pics were dumped in a forum update.
C-Notch-
Articles-
"Refining Sierra"
Old 09-12-2008, 06:14 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Valves/tanks-
Articles-
"Refining Sierra"
Old 09-12-2008, 06:16 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Rear bags/Panhard-
Articles-
"Refining Sierra"
Old 09-12-2008, 06:24 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
What I can't find is pics of the mods that he did to the rear wheel tubs. I'll dig some more, or maybe someone else can post them.
Articles-
"Refining Sierra"
Old 09-12-2008, 09:25 PM   #11
lofly'a
lofly'a's Avatar
So N2TRUX, is that the max notch that can be attained before the punkin hits the bedfloor.
Old 09-12-2008, 11:00 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, that's about as close as you can get. The top of the pumpkin is very close to the bed if you air out with no stops. On my 77 we put small flat stops in there in the event of system failure.
Articles-
"Refining Sierra"
Old 09-13-2008, 02:21 PM   #13
lofly'a
lofly'a's Avatar
what are u running on the front, i am thinking bags and drop spindles will give me the profile i'm wanting, and i am thinking alignment at ride height and maybe any bumpsteer issues. i will be using sway bars front and rear as soon as i come across a HD 4th gen rear bar. i really like your notch, my blazer's is similar. looks a lot cleaner than the bolt on "side plate" and i believe inner-braces are very neccesary after any notch especially if you plan to carry anything in the bed or tow anything.
Old 09-14-2008, 12:01 AM   #14
spr85gmc
spr85gmc's Avatar
does any one have pics of 80 body styles
spr85gmc is offline   Reply With Quote
Old 09-14-2008, 05:12 PM   #15
Painter D
Painter D's Avatar
Here's mine. No bed floor mods.
Painter D is offline   Reply With Quote
Old 09-14-2008, 06:37 PM   #16
hotrodhomi
hotrodhomi's Avatar
Rear end touches the bed floor when dumped.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 09-16-2008, 12:02 AM   #17
lofly'a
lofly'a's Avatar
thanks guys, thats what i'm shooting for. your rides are "fly". i love the stances.
