Old 09-11-2008, 11:23 PM   #1
crasten123
crasten123's Avatar
Help...tilt column i.d.
I purchased this tilt from a guy who said it was for a 72 Chevy pu. After looking at it, I'm not sure. Can anyone help? Does anyone have the dimensions (length of the column). Any information to help I.d. this would be helpful.
[B]72 Cheyenne SWB
crasten123 is offline   Reply With Quote
Old 09-11-2008, 11:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Help...tilt column i.d.
looks like the real deal to me.
Old 09-11-2008, 11:34 PM   #3
crasten123
crasten123's Avatar
How can you tell? I've seen most pics with the linkage lever straight...and not "dog legged" like this one. Plus the Neutral switch seems to be higher up on this one, vs lower to the bottom of the column on others I've seen.
[B]72 Cheyenne SWB
Old 09-11-2008, 11:37 PM   #4
corn
Trucks have the short splined shaft at the end like yours does...
corn is offline   Reply With Quote
Old 09-11-2008, 11:56 PM   #5
crasten123
crasten123's Avatar
Is the base plate correct?
[B]72 Cheyenne SWB
Old 09-11-2008, 11:59 PM   #6
crasten123
crasten123's Avatar
here's another pic of the arm the attaches to the transmission linkage. Is this correct for a 72 pu?
[B]72 Cheyenne SWB
Old 09-12-2008, 12:03 AM   #7
Classic Bowties
Always on the hunt...
After looking at the pictured shift arm that one originally came out of a motor home, but should fit, mount and function fine in your truck. I can not make out were the neutral safety/back up light switch is on that one but a lot of the time those short splined shaft motor home columns have two locations to mount the switch, you want to use the lower slot closest to the firewall otherwise the switch can interfere with mounting column into the dash.
Classic Bowties is offline   Reply With Quote
Old 09-12-2008, 12:07 AM   #8
Classic Bowties
You just posted some better pics, that type of lower mounting plate/floor seal is the one used in motor home applications.
Old 09-12-2008, 12:14 AM   #9
crasten123
crasten123's Avatar
So...no modifications needed? If so, I would be pretty happy. The neutral switch is up near the middle of the column (below the masking tape in picture). Would I still be able to mount the switch there...or would I need to cut a "rectangle" near the base?
[B]72 Cheyenne SWB
Old 09-12-2008, 01:06 AM   #10
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
You will have to relocate Switch lower.Here is a pic of a genuine truck tilt.
KevsClassics is offline   Reply With Quote
Old 09-12-2008, 05:40 AM   #11
Longhorn Man
after the second set of photos, I agree, motorhome
