newly minted old timer
tranny issuse
Today, I had a lifter needing some more adjusting, and the bumpers needed installing, so we did that. Got everything running, and took off for a test drive. When I tried to put it into L2 it wouldn’t go past drive.
Very strange indeed, all of a sudden with no work done to the trany or anything even close to it. I have not had time to check into the linkage other than just a visual from the engine compartment. I thought maybe the dipstick broke, but its fine. Thought maybe the linkage had come loose and was fouling itself but its ok, seemingly, too. Anyone had this happen before? Ideas? its as th350 auto btw
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban Last edited by mtdave2; 09-11-2008 at 11:33 PM. |
Re: trany issuse
Its almost gotta be in the linkage somewhere.
Re: trany issuse
thats what i was thinking, but you can see the whole thing move from the top,,,,hum if it wasnt dark out id......lol
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
Re: trany issuse
Take it off at the end of the column. You will be able to tell if its in the column or linkage going down from there...
Re: trany issuse
ya, that was the plan, tomorrow in the light!
I'm a poor spectator
Re: trany issuse
Scrap it...
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Re: trany issuse
Maybe your bumper bolts are too long.
Future TOTM Winner
Re: trany issuse
I had similar problems on my 68 years ago. I am betting that when you pull the linkage off the end of the column you will find that the transmission shifts fine but the column is binding up. If this is all it is then pulling a few parts off and greasing/oiling will fix your problem. When you shift from P-R-N-D does the shift lever pull towards you easily or not? In other words, the shifter should move and inch or two towards you and freely "spring" back into place. If not then it is definitely a gummed up column.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#9 | |
Re: trany issuse
Re: trany issuse
hey i did that have that problem today! lol, how did you know...lmao
Re: trany issuse
well... as some of you know i bought one of the new aftermarket ramhorn exhaust manifolds. They look great, seam to be good quality, they fit great, I would recommend them…
however….they do fit just a bit different and it moved the exhaust into the line where the shifter moves. So it bottoms out in drive..lol, I can feel he shifter moving when I tap the gas. Not a hard fix really, but im going to let my favorite old Mexican exhaust guy do it, and build me a few more hangers. Im happy that it wasn’t the trany.
Future TOTM Winner
Re: trany issuse
That's good news for you. Glad it was something simple.
