Old 09-11-2008, 11:36 PM   #1
big_al_71
big_al_71's Avatar
Header issue
I bought a set of doug thorley headers for my small block 400. I went to install them tonight and I came accross an issue. The left side header fits perfect however the passenger side bolts right up but the number two spark plug there is zero room between the spark plug and the header tube, the spark plug wire does not fit in there period. I attached some picts to give you guys an idea of what I have encountered. I am a bit dissapointed as I am so ready to drop this motor in and get it going, now I am at a stand still. I called nick @ doug thorley headers and emailed him as well the picts hopefully he will get me all ready to go quickly. Has any of you ever had such issue? I have built several engines over my years and have never had this happen.
Any ideas or thoughts?
Al
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-11-2008, 11:41 PM   #2
corn
Re: Header issue
Looks like you might need to get a set of Accel shortie plugs...
corn is offline   Reply With Quote
Old 09-11-2008, 11:45 PM   #3
big_al_71
big_al_71's Avatar
Re: Header issue
Thats a thought!!!
any idea on what part number I would need.?
I hope this works so I dont have to be dealing with credits and shipping and all that non sense.
I am getting one new plug today to see if that works. Other than that I am waiting for nick to call me to see if there is a different part number for straight angle plugs headers. I will just keep my fingers crossed hoping that the shorter plug will solve my problem.
thanks for any and all feedback.!!!
AL
Old 09-11-2008, 11:49 PM   #4
mtdave2
newly minted old timer
mtdave2's Avatar
Re: Header issue
that kind of thing can drive a guy to drink lol.. the short plug is a great idea!
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-11-2008, 11:52 PM   #5
big_al_71
big_al_71's Avatar
Re: Header issue
You are not kidding, I know that I am going to come across many snags while I am doing this rebuild of my truck, just did not expect this one. This is definetly a first for me.
Old 09-11-2008, 11:58 PM   #6
corn
Re: Header issue
http://accel-ignition.com/AskTechRes...dID=&ID=112543
Old 09-11-2008, 11:59 PM   #7
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Header issue
Big Al
Check out this link and I have PM'd you some useful info that Jim_PA sent to me.
http://www.sparkplugs.com
Try Accel 0414S (http://www.jegs.com/i/Accel+Spark+Pl.../414S/10002/-1 )
Here is the recommendations from edelbrock.
Under 9.5 to 1 Compression
Champion ---------- RC12YC / 2071
NGK --------------- FR 4 / 5155 OR BCPR5ES / 6130
Autolite ------------ 3926
Motorcraft --------- AGSFP52
Accel Shorty ------- 0416S
Up to 10.5 to 1 Compression
Champion ----------- RC9YC / 2075
Autolite -------------- 3924
NGK ----------------- FR 5 / 7373 OR BCPR7ES / 3330
Accel Shorty -------- 0414S
11 to 1 Compression
Champion ------------ C63YC / 796
NGK ------------------ R5672A-8 / 7173
12 to 1 Compression
Champion ------------- C61YC / 785
NGK ------------------- R5672A-9 / 7405
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 09-12-2008, 12:04 AM   #8
corn
Re: Header issue
Im not sure the # I found is the correct heat range for your motor. The local oreilly's here carries them, may be worth looking in your area...
Old 09-12-2008, 12:05 AM   #9
trx450duner
trx450duner's Avatar
Re: Header issue
Maybe those headers were built for angle plug heads? I've got it figured out, you can send me those heads and order up some angle plug heads to replace them and we will all be happy
trx450duner is offline   Reply With Quote
Old 09-12-2008, 12:10 AM   #10
big_al_71
big_al_71's Avatar
Re: Header issue
Sure buy me the angle plug heads and we call it even!!!
Old 09-12-2008, 12:11 AM   #11
corn
Re: Header issue
If those headers weren't so darn purdy, you could just get out the BFH.
Old 09-12-2008, 12:12 AM   #12
big_al_71
big_al_71's Avatar
Re: Header issue
Thank you for your help,,, I will try this tomorrow to see if the 45 degree boot will fit and not touch the header, maybe I can cross over my part number and just buy one spark plug....to try.
Old 09-12-2008, 12:13 AM   #13
big_al_71
big_al_71's Avatar
Re: Header issue
Believe I thought of that but I dont want to rig anything I want it as close to perfect as possible
Old 09-12-2008, 12:14 AM   #14
big_al_71
big_al_71's Avatar
Re: Header issue
Originally Posted by Arad68 View Post
Big Al
11 to 1 Compression
12 to 1 Compression
thanks don!!!!
Old 09-12-2008, 12:15 AM   #15
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Header issue
I had to use those damn shorty spark plugs on my blazer, there expensive compared to regular plugs, like 5 bucks a piece, i'm not used to paying more than 1.50 for the regular ole cheapies. I also had to use the 90 degree boots. I bought the universal wires that you cut yourself and it came out real clean, well worth it IMO.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-12-2008, 12:25 AM   #16
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Header issue
Your welcome!!! Spark plugs and ignition can be something like a black art without help.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 09-12-2008, 06:59 AM   #17
c10crazy
Like a Rock!
c10crazy's Avatar
Re: Header issue
Al that motor is sweet!!! What heads are they and what are the details/part number for the pulley kit??? Did you buy the headers directly from Thorley??
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 09-12-2008, 07:23 AM   #18
big_al_71
big_al_71's Avatar
Re: Header issue
The heads are 70cc straight angle plugs from edelbrock part number 60759
The pulleys are from March Pulleys but I cant remember the part number at this time however I can get it for you when I get to my shop.
Yes I bought the headers directly at a GREAT price from Nick
951-739-5900 ext 217.
Old 09-12-2008, 07:31 AM   #19
70GMCer
70GMCer's Avatar
Re: Header issue
It is still a shame that "most" of the "great header engineers" cannot come up with a header that fits without either using the BFH, or buying special plugs, wires, insulators, etc. It's been that way since the beginning. I'm not just talking trucks either. Maybe they get kick backs from those makers of those products. IMHO
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-12-2008, 07:40 AM   #20
big_al_71
big_al_71's Avatar
Re: Header issue
I went with this header just because of that, they claimed that they are "specially" designed for our trucks. I know that they engineer some great headers, maybe this is just an isolated case. We will see, wish me luck...
Old 09-13-2008, 02:46 PM   #21
big_al_71
big_al_71's Avatar
Re: Header issue
Thanks to all you guys suggestions I have my problem solved....the accel 414s smaller header plug did the trick!!!!
