09-12-2008, 08:26 AM | #1 |
English Chevy Owner
Trouble sourcing PCV Grommets
I have a set of Micky Thomson valve covers to go on my 350 but I'm having real trouble over here in the UK sourcing the right size PCV grommet. The hole (already knocked out) in the cover measures at a diameter of 1 3/8" and I'm struggling to find one that size. Can anyone suggest a mail order source.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
09-12-2008, 09:12 AM | #2 |
Out of the carpool lane.
Re: Trouble sourcing PCV Grommets
That seems like a pretty big hole for the PCV, are you sure it's not for the breather cap instead?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
09-12-2008, 09:35 AM | #3 |
English Chevy Owner
It has a push and twist hole at one end and this 1 3/8 hole at the other. One cover has the 1 3/8" hole opened up and the other the push and twist so I was going to put the breather/oil filler in the push and twist hole and the PCV in the other. I'll take some pics if that would help.
09-12-2008, 07:42 PM | #4 |
Yes, pics would help.
09-12-2008, 07:57 PM | #5 |
I recently replaced all my grommets ..had a oil fill, a carb spacer/breather, and a pvc. Got them all at Carquest. They had a bunch of em on a rotating display. Hope thats not to obvious a source. Good luck
1972 K-10 SWB Cheyenne |
09-12-2008, 08:28 PM | #6 |
Between Trucks...
I think the OP is in England.
Beat it to fit, Paint it to match... |
09-13-2008, 08:13 AM | #7 |
English Chevy Owner
Yep, good old England where it never stops raining.........hence the request for mail order. Suppliers over here only seem to keep 1 1/4 ones in stock.
inside
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission Last edited by Lippyp; 09-13-2008 at 10:05 AM. |
09-13-2008, 10:27 AM | #8 |
I would try the 1 1/4" grommet.I think the hole in my Clifford valve cover was 1 3/8" and 1 1/4" worked fine. Chris
09-13-2008, 11:19 AM | #9 |
English Chevy Owner
I've just looked at the other cover that has the opposite holes knocked out and it looks like the PCV hole is stepped so you can just knock out the middle or the whole, well, hole and the previous owner knocked the large hole out. A 1 1/4" grommet does stay in but it is a little loose, I was thinking maybe a small bead of black TRV sealant around it might be the only way forward to avoid any oil leaks.
09-13-2008, 12:27 PM | #10 |
09-13-2008, 02:25 PM | #11 |
I found these:
https://www.yearone.com/serverfiles/...T66803&Style=4 But if you want some advice 'sell them' and get something else. Or at the very least put some baffles inside to stop oil from slinging out the holes. I had some and could never keep them from leaking, finally sold them.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-13-2008, 04:58 PM | #12 |
laying low
Lippy it looks like Year One has you covered with either size grommets for steel or aluminum valve covers.
A bead of silicone to try what you have or have someone do a little bit of welding on your cover to tighten up the hole maybe?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
